Easy 19" front wheel for FXFBS
My Favorite FAT BOB around the block! loving the look with the 19" conversion, so you said it was a straight bolt on project, and im curious about it, really no other hardware mount, bearings or something else needed ??
With this conversion no need to look for a Low rider S anymore!
Haven't gone down that road again but I now found a 2020 RGS wheel that I'm interested in so may be trying it again. One thing to keep in mind is the front fender will look good from the side but looking at it from the front, it reminds me of a kid wearing his dad's hat. It's just a bit too wide is all. Apparently FLD 103 swapped his with a LRS fender and that was a direct bolt on as well. Good luck. The Fat Bob does look great with the 19" front wheel.
maurino17 (02-20-2024)
From what's in his first post, FLS103 states any touring model front wheel from 09 and up should be a direct fit.
I know FLS 103 doesn't come on here often but to answer your questions, yes it's a direct bolt on with no other hardware needed. I did it on mine as well following suit but the wheel I got was warped or bent or just cast with a hump in it so I returned it to the seller and got my money back.
This was not a problem for me as I intended to and did go with a 110/90 front. The issue with the 110/90 was that it's really designed for a wheel with a Max width of 3" and the touring wheel was 3.5". I got it to mount and seal but it just didn't quite look right and because the tire was spread out it was real easy for me to run out of tread because of the way I lean.
Ended up with a 120/70 front. Fender gap looked good from the side and the width looked good from the front. The 120/70 also mounted easily and had the correct profile as it was designed for a 3.5" wide wheel.
I ran Metzler Cruisetec tires because they ran a little taller than other brands and I have always liked their tires. Excellent profile on these if you like the twisties.
08xl1200r (04-19-2021)
Liking my bagger but I miss this beast
Bowhunter8607 (05-21-2020)
The following 3 users liked this post by FLS103:
