Hold-Fast luggage rack rattles
I installed the new version of the detachable hardware on my 2019 LowRider. There does not seem to be any adjustment in the hardware and I can hear the luggage rack rattle at low speeds. It is annoying. Any suggestions for stopping the rattle on the new detachables?
If the upright or rack rattles once installed, docking points must be adjusted.
1. See flats (F) in Figure 5. To adjust, rotate in small increments so that the flat is no longer horizontal and approaches position (E).
NOTE
3. Continue rotation in small increments and check accessory fit until desired tightness is achieved. The tightest possible position is when the flats reach position (E).
4.Tighten docking point screws.
Torque: 28.5–37 N·m (21–27 ft-lbs)
NOTE
Maximum achievable tightness are when the flats are perpendicular to the ground. At each increment, check upright or rack for fitness.
2. At each increment, check fit with accessory.3. Continue rotation in small increments and check accessory fit until desired tightness is achieved. The tightest possible position is when the flats reach position (E).
Heathen Big Chris
12-03-2012 12:46 PM
