Sport glide bar swap questions
I want to change my bars out on the sport glide even though they feel almost perfect. I’d like them maybe 2-3 inches higher and the controls to be in about 2 inches. I’ve watched a couple YouTube videos on swapping the bars. The one I watched was very detailed, but he put on ape hangers, so clutch and brake lines needed to be changed out. I should be fine with stock.
Since im not changing the lines out there is no need for me to open up the trans cover correct? All I’m really doing is removing the wiring and fishing it through new bars and changing the controls over.
Any suggestions and pics of your bars would be good. Right now I’m looking towards the chubby pullback drag bars on denniskirk.com
Don't change out your bars if they "feel almost perfect". You've already got the right bend for your style. All you need are some different risers to get the bars higher and back a little.
Here are some from Harley that should do exactly what you want: https://www.harley-davidson.com/stor...ebar-riser-kit
That's the top quality stuff at the top price (maybe 15-20% cheaper from Surdyke). But if you don't mind aftermarket, you can probably find a nice set for $50 to $60, or maybe a used OEM set from another bike cheaper.
The best part is that this will be a really easy job. Much easier than swapping the bars!
I am debating whether going with the Lucky Dave bars or the Westcoast MX-Tbars. The Westcoast bars are 31 1/2 inches across and also come in different heights. I prefer their 8 inch height bars, keeping the total height of the bars around the height of that small fairing windshield.
I haven't looked yet but I am concerned If I can pull the wiring harness through the holes of the bars without disassembling the electrical connectors. Having to disassemble them would be painful.
You may want to look into the Luck Dave 13 bars. They have a pull back and are 28 inches across whereas the Sport Glide's width is around 33 1/2 inches. From a quick measurement I took it looks like the total height of the Sport Glide bars are about 7 inches. The Lucky Dave 13 bars start at 11 inches in height. They are pretty popular in California where lane spitting is allowed.
those west coast bars sound like a good option. Like I said I like the stock feel and I think those sound like they are pretty close to stock. Keep me posted on the wire plugs. I’ve only watched 2 videos, one had a plug and play harness in the bars already(ape hangers) and the other one had John maxwell taking apart the plugs.
Right around the installer shows the connector which is quite small. If that's the connector size I think its good news.
I also wanted just a couple of inches higher and a couple of inches closer. The H-D 4” fat pullback risers linked above fit the bill perfectly with no cables needed and a simple install.
The stock bars are slightly wider than my shoulders, but the new position made them a comfortable fit with a relaxed arm bend and less forward lean.
If you don’t like the chrome, you could always get a cheap used bar and riser set and have them powder coated.
Jersey Drew
2014-2023 Touring Models
19
08-22-2018 01:48 PM
