2018+ Softail Models Breakout
Sport Glide mods
Old 08-01-2019, 09:45 AM
Otterclan's Avatar
Otterclan
Otterclan is offline
5th Gear
Originally Posted by rbouillion
Anyone find a Fork Clamp Turn Signal Mounts to fit the Sport Glide? Trying to relocate them to the forks however the largest I've found where 54/58 MM(Kuryakyn 2-Piece Universal Fork Clamp Mounting Brackets) that are too small.
I also could never find a clamp that would fit so I used the existing memphis lower clamp for fairing. Found an L-bracket, drilled holes and used longer bolt for the added bracket. Hope this helps
  #52
Old 08-01-2019, 06:05 PM
Ralibur's Avatar
Ralibur
Ralibur is online now
  1. [img]blob:https://www.hdforums.com/93afad1d-a77d-4b4e-9934-48d898ed4e6a[/img]
  #53
Old 08-01-2019, 06:40 PM
rbouillion's Avatar
rbouillion
rbouillion is offline
Default Thanks
I thought I see in your pictures that you had somehow attached them to the fairing.
I really want them on the forks because I'm anticipating wanting to switch between the stock fairing and the Memphis on a fairly routine basis. Most of my riding are short one hour long rides near the house (South Louisiana Heat).
I bought the Memphis primarily for longer rides in colder temperature.
I think I'm going to try to have the Kuryakyn clamps machined out.
QUOTE=Otterclan;18443708]I also could never find a clamp that would fit so I used the existing memphis lower clamp for fairing. Found an L-bracket, drilled holes and used longer bolt for the added bracket. Hope this helps[/QUOTE]
  #54
Old 08-01-2019, 07:59 PM
Daedalus1066's Avatar
Daedalus1066
Daedalus1066 is offline
[/QUOTE]
Are you going to be moving the Memphis mounting hardware? It was my understanding once that is mounted you will not be able to use the HD fairing as it will not fit.
  #55
Old 08-02-2019, 05:46 AM
rbouillion's Avatar
rbouillion
Yes, you are correct. You do have to either remove or reposition the Memphis mounting hardware to reinstall the HD Fairing. That is my initial plan however, I plan to study possible modifications to the back of the HD Fairing to see if I can't somehow get it to fit without having to remove or reposition the Memphis mounts.
Haven't decided to go that far just yet. I'm having the Memphis Fairing painted next week to match the bike. Who knows I may like it enough to leave it on permanently.
I'll post pictures when I get the fairing back from paint.
  #56
Old 08-10-2019, 03:37 AM
Aussie HD's Avatar
Aussie HD
Aussie HD is offline
Few mods compared to stock.
The following 5 users liked this post by Aussie HD:
bb944 (04-12-2021), GPHDXLC (10-03-2020), JakeC7R (09-20-2019), rauchman (02-12-2022), Truble (06-22-2020)
  #57
Old 08-10-2019, 04:26 AM
Agoober's Avatar
Agoober
Agoober is offline
Received 1,008 Likes on 714 Posts
Great lookin' scoot dagnabit !
I wouldn't do any of those changes in isolation or piece by piece for me but as a whole it looks badass.
Peace.
Aussie HD (08-19-2019)
  #58
Old 08-10-2019, 07:32 AM
jtodd's Avatar
jtodd
jtodd is offline
Looks great. Would love to see a view from the front. What bars are those? Thanks
The following 2 users liked this post by jtodd:
Aussie HD (08-19-2019), Truble (12-21-2019)
  #59
Old 08-10-2019, 08:03 AM
chilled's Avatar
chilled
chilled is offline
custom dynamics have them in black,go to customize black 50.8mm / 2inch
https://www.customdynamics.com/tube-...ullets?cat=368
  #60
Old 08-10-2019, 09:07 PM
Ralibur's Avatar
Ralibur
Hello Aussie HD,
Your Sport Glide looks great, especially with the V&H Big Radius Pipes. I also have a Sport Glide but with an HD SE performance exhaust. Shortly I will be installing a SE torque cam and would like to buy the Big Radius pipes, but have not been able to talk to anybody who has them locally, so I would like to ask you a couple of questions.
Low end torque, did you perceive any loss with these pipes?
Sound, what baffles do you have in them and what do you think of their sound.
Drone effect, after an hour ride, does your head feel numb?
Thanks
Ted
Quick Reply: Sport Glide mods
