Sport Glide mods
#91
Ares,
i did relocate clutch cable cable under the bars after the riser upgrade and a few hundred miles. I agree with others that is seemed a bit taught with the cable on top of the bars but mechanically I felt no difference. The seat upgrade was the first I’ve done. Comfort wise was a big gain for me lady, me a little comfort gain with a bit more of a tight cradle. The nose of the seat is about an inch or so shorter than the factory seat even with my best manipulations. So you do see the bottom edge of the tank and partially exposed tank strip bolt. But it does sit securely. Hope this help. Ride safe
Landshaper (09-13-2019)
#92
here is a list of mods i made to my 2019 Sport Glide
Memphis Shades batwing with 5" windshield in black
relocated turn signals and added CD LED inserts
CD sequential light bar
HD Engine guard and soft lowers
4" curved risers and chrome switches
Stage1 Ventilator + SE street cannons + SEPST
I use my old power vision to monitor her vitals
Garmin drive 60 gps
Soft lowers are so good at eliminating buffetting, i might replace them with hard permanent ones.
So far I am super happy with the bike
Garmin drive 60 gps
#93
#94
Garmin drive 60 gps
Garmin drive 60 gps
Exactly what I want to do the sport glide. What parts did you use for turn signal relocation?
#96
Am looking at a 2019 SG. I'm short , but can flatfoot it no problem. The bars have to come back at least 3 inches and I am used to floorboards on my Heritage and former Ultra. "Chilled" , I see has what looks like Heritage floorboards on his bike. With the single point mount, can I simply swap the pegs for the boards ? I see aftermarket boards that are smaller but also appear to further reduce lean angle and I like the factory looking boards. Is this an easy swap ? Also will the 4 inch pullback risers reduce my reach by a couple inches ,or maybe 6 inch pullbacks be better ?
#97
#98
Belloc42 posted this https://www.hdforums.com/forum/softa...t-glide-4.html
50500751 Fat Boy Mounting brackets
50500753
33600128 Shift lever bracket (includes bearing sleeve) - attaches to mount on shift side
10200350 Screws to attach shift lever bracket to mount - need 2
50500699 Pin (holds board to mount) - need 2
50500700 Spring - need 2
50500701 Clip (keeps pin in) - need 2
50500564 (right) Heritage footboards (includes rubber insert and wear peg)
50501087 (left)
also 4" pullback risers work really well for me
putting up loads of miles on mine this year and happy out with the setup
#99
I put Softail Deluxe floorboards on my Heritage, they support the riders feet better due to their shape. They are wider at the front and you do not loose any cornering clearance. You may want to consider them.
icybeam (04-01-2020)
#100
Hey rbouillion,
Where did you get the fork clamps for your turn signals? I ordered a new fairing and I need to move the turn signals, someone esle mentioned CD had something that would fit but I called them and the girl I spoke with said the biggest they had was 1 3/4"
Your fairing and bike look great by the way!
