2018+ Softail Models Breakout
'18 FXLR Fork Tube Diameter
Old 01-02-2019 | 08:07 AM
ole_phart's Avatar
ole_phart
Default '18 FXLR Fork Tube Diameter
I'll be replacing the handlebars and thinking about relocating the front turn signals to the fork tubes at the same time so I need clamps. Can anybody confirm that they are 49mm? I took a SWAG with a ruler and would rather not buy a caliper that I'd use once. Thanks!
-jeff
Slyvest (02-22-2020)
Old 01-02-2019 | 08:35 AM
wadejesu's Avatar
wadejesu
49mm front tubes
Old 01-02-2019 | 08:49 AM
ole_phart's Avatar
ole_phart
Originally Posted by wadejesu
49mm front tubes
Hey, thanks much! In addition to liking the looks better, that's 2 less cables to run through the handlebars.
Old 01-29-2019 | 06:04 PM
AJ88V's Avatar
AJ88V
Thanks for posting this. I used something like these from Amazon on my Dyna and they worked out great.
https://www.amazon.com/Motorcycle-Signal-Softail-Bracket-CHROMED/dp/B00XIRXRH0/ref=sr_1_20?ie=UTF8&qid=1548802880&sr=8-20&keywords=harley+front+turn+signal+relocation https://www.amazon.com/Motorcycle-Signal-Softail-Bracket-CHROMED/dp/B00XIRXRH0/ref=sr_1_20?ie=UTF8&qid=1548802880&sr=8-20&keywords=harley+front+turn+signal+relocation
I liked that they don't tap into the bolts holding the tubes to the lower trees. It would make me nervous to have the bolt hold the forks together running through a pot metal casting.
Old 01-29-2019 | 06:49 PM
OldMike's Avatar
OldMike
The pot metal ones used to work OK, but nobody has one for the new tree profile.
I thought about the clamp mount but have my signals just up on my new bars for now.
Have a (working on) idea for a stand off to mount to the tree. I'll post some pictures when I get all the parts in so anybody can copy.
Old 01-29-2019 | 10:23 PM
Mchad's Avatar
Mchad
I used a HD Dyna relo kit. Fit perfectly and is of excellent quality.
https://www.harley-davidson.com/stor...-11-6943308--1
Old 01-30-2019 | 05:10 PM
AJ88V's Avatar
AJ88V
That couldn't possibly work! I checked the fitment and it only lists up to 2017 Dyna models.
(mandatory icon to indicate humor in case anybody should interpret otherwise: )
Old 01-30-2019 | 11:42 PM
XXTHESANDMANXX's Avatar
XXTHESANDMANXX
https://www.amazon.com/Motorcycle-Si...nal+relocation
I got the same ones,
digthemlows
09-08-2015 04:26 PM
gatorfrey
10-19-2014 05:20 PM
Smokin 03
08-28-2013 09:34 AM
tattoofever
05-21-2013 08:18 AM
jtbredneck351
Ironhead
05-07-2010 08:58 PM
Quick Reply: '18 FXLR Fork Tube Diameter
