2018+ Softail Models Breakout
Everything 2018 FatBoy thread
Old 02-11-2021, 12:58 PM
OldMike's Avatar
OldMike
OldMike is offline
Received 1,929 Likes on 1,262 Posts
Originally Posted by skak
It's just the Screamin' Eagle 131" kit out of the box. I have the Rinehart exhaust and FP3 tuner. Looking at a Cycle-Rama CR512 cam that I'll put in myself once I gather all the parts together.
Sounds like a good plan.
wjcbsr (02-12-2021)
  #512
Old 02-12-2021, 09:26 AM
wjcbsr's Avatar
wjcbsr
wjcbsr is offline
It is yes!
  #513
Old 02-12-2021, 12:14 PM
wjcbsr's Avatar
wjcbsr
wjcbsr is offline
Default 131" Upgrade Post-Op Run
The following 6 users liked this post by wjcbsr:
FranBunnyFFXII (02-12-2021), Heed (02-12-2021), MoneyFor (02-14-2021), OldMike (02-12-2021), pinoy (02-14-2021), Stormin70 (02-12-2021) and 1 others liked this post. (Show less...)
  #514
Old 02-12-2021, 12:26 PM
OldMike's Avatar
OldMike
OldMike is offline
Bad ***!
Thanks for rolling it out, get a better idea of the sound.
Bet you can't wait.
wjcbsr (02-13-2021)
  #515
Old 02-12-2021, 01:49 PM
MegaTron's Avatar
MegaTron
MegaTron is offline
Where’d you get that sissy bar?
  #516
Old 02-12-2021, 01:51 PM
MegaTron's Avatar
MegaTron
MegaTron is offline
what sissy bar is that?
  #517
Old 02-13-2021, 10:15 AM
wjcbsr's Avatar
wjcbsr
wjcbsr is offline
Top Hand Ventures. Great people to deal with too!
https://www.tophandventures.com/
  #518
Old 02-13-2021, 06:13 PM
BLKBETY's Avatar
BLKBETY
BLKBETY is offline
Originally Posted by HD-IRON
I have a new 2018 114 FB. Sometimes getting it in neutral is difficult when I am parked, and have finished riding, so I will just cut it off while in gear with clutch pulled in. When I go to start it back up, I will pull the clutch in and start it in gear. My question is, is it hard on the bike to start it with the clutch pulled in while in gear? Will it damage anything? I would rather start it in neutral, but if there is no harm starting it with the clutch in while in gear, then that is good to know.
Clutch adjustment mate , 99% will solve your issue. My 2020 in first 1500 was a Bi$%h took it in for first service which clutch adjustment is part of, and it now clicks though beautiful and gets natural no dramas at all, lightest click, boom natural.
It is easy to do if your that way inclined. Pop derby cover, loosen jam nut back out Allen key . Back of clutch cable by unclipping lock on cable adjuster push together and lock in retracted position, wind the adjustment bolt in till it JUST touches no more, double check your self, then 3/4turn in, lock jam nut, 10ftlb I think it is, unclip cable lock it self adjusts, then lock it again. Check cable and level free play, check clutch basket movement. Install derby cover and new seal.
  #519
Old 02-20-2021, 10:33 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
FranBunnyFFXII is offline
Received 2,945 Likes on 1,596 Posts
Hey guys quick question, do the floorboard inserts on the bike flex and tilt around?
I was watching this guy install something on his roadglide and I noticed when his foot when moved around on the floorboard surface it would tilt and flex in that direction.
Do the floorboards that that on the fat boy?
  #520
Old 02-20-2021, 11:14 PM
iHodor's Avatar
iHodor
iHodor is offline
I haven't noticed mine doing it Fran, and I mount and dismount from the right side while standing on the floorboard.
Quick Reply: Everything 2018 FatBoy thread
