Everything 2018 FatBoy thread
#1631
I put new brake pads on the front, I did the back quite a while ago.
I went with Lyndall Z Plus, they are supposed to be dustless. The big solid wheel is pourus, and really sucks up the bake dust, very hard to get clean.
These were the origianal pads, I have 23,375 miles on them, they were pretty low, the wear groves are non-existant.
#1632
#1633
#1636
I keep them and when the bike is sold I reassemble them, when you sell the bike, it is rare that you can calculate the added value of aftermarket parts.
When you sell them separately, these aftermarket parts are easier to sell and have a better value than OEM parts.
Urban Gorilla (03-14-2024)
#1637
After some advice and help....
On either side of the swinging arm are black plastic grommets - I'm guessing these can be removed and used as an alternate location for the passenger pegs
...but how do you remove them?
Are they press fit or screwed in?
Here's a pic to show the location on one side of the bike.
TIA
TIA
#1638
TIA
TIA
Also your bike wont have the upper mounting locations if its 2018 model year. It was in 2019 that the Breakout and Fat Boy got upper peg mount locations. For some reason in the 2018MY, they used a different structure for those under seat struts.
Right side can't use the upper hole either because of the exhaust, which is why the exhaust hanger has a mounting point on it.
#1639
I used a pair of needle nose pliers to get them out of the peg mount points so I could install my Crashbar.
Mines a 2019MY
No issue with clearance on either side for the pegs (exhaust side not an issue with the shortshots)
Just finding them an absolute PITA to try and remove.
So they should just pull out right?
#1640
If you have a sharp pocket knife, you can stab the center and make another grip point to grab at them.
Urban Gorilla (03-16-2024)
