Everything 2018 FatBoy thread
#1321
#1322
Henboykin (02-01-2023)
#1323
There's a painter out in my area that I might be able to re-clear my bike's fenders and tank, and I was thinking afterwards to truck bed liner on the bottom to protect it for life.
I've been doing durability upgrade stuff to my bike and have been thinking about paint protection choices.
#1324
I undercoat the fenders too, they hardly put any paint on these things at all. And as for the fenders, that stupid lip they do is sharp so paint is never going to stick to it at the best of times.
If they bent your fender that much did you manage to get it back into shape? ...I would have thought the paint would have cracked on the top as well as just the lip ...mind you, the last 2 bikes I had got chips in exactly that point and then the water, then rust gets in. I use PPF on the leading edge. It is noticeable, but a lot nicer than rust bubbling under the paint
#1325
Doublefelix (01-25-2023)
#1326
#1328
The main thing that I'm having done is getting the Wheels painted - the inserts to be specific.
The wheels should look like this when done
Picture was painstakingly edited using MS Paint.
At the same occasion I'll be painting (Gloss Black) the inner part of the brake discs and belt drive pulley.
However, I've been acquiring parts to do a bit of a cosmetic makeover, which I've already had some parts painted:
Somewhere in the timeframe, I'll be getting the secondhand Tank I have lined and painted (I already have another complete Fuel Pump Assembly).
Plus some custom paint work on the tank console.
Later on down the line I have a Stage 1 kit to install consisting of:
- Rick's Motorcycles Steel Front Fender (Gloss Black)
- OEM rear fender and fender rails (Gloss Black)
- Lumitecs TX1 LED turn signals with rear and brake light
- LED Motorcycle Rear Fender Brake Tail Light
- OEM wiring connections, pins and colour coded wiring
- Savage Rear Number Plate Tidy
- Highway Hawk Chrome Motorcycle Number Plate Holder Surround
- Red Number Plate Reflector Bolts
- DK Customs Passenger Footpeg adapters
- Kuryakyn Zombie Passenger Pegs
- DK Customs, Rider Floorboard Relocation
- H-D Gloss Black Inner Shift Rod Lever
- Kuryakyn Zombie Gear Shift Linkage
- SoftBrake Extended Shift Lever
- Kuryakyn Zombie Gear Shift Peg
- SoftBrake Extended Brake Pedal
- Kuryakyn Zombie Brake Pedal Pad
- Thunderbike Rear Axle Cover Set
- Thunderbike Left & Right Side Swingarm Axle Covers
- WillyShine Front Axle Cover Set
- Gloss Black Belt Guard
- Vance & Hines Staggered Shortshots with Thunder Torque Inserts (TTI-158)
- Vance & Hines V02 X Air Intake Black Contrast with DK Customs, Premium Catch Can EBS Breather System
- Vance & Hines FP4
- Screamin’ Eagle 55mm Intake Manifold
- Screamin’ Eagle Performance Spark Plugs
- Twin Power Ignition Coil
- DK Customs, 409 Pro Race Black Spark Plug Wires
The following 3 users liked this post by Urban Gorilla:
#1329
The following 3 users liked this post by FranBunnyFFXII:
#1330
- Vance & Hines FP4
Urban Gorilla (02-09-2023)
