2018+ Softail Models Breakout
The Everything 2018+ Heritage Thread
Old 05-24-2021, 05:12 AM
tmac00333's Avatar
tmac00333
tmac00333 is offline
Received 1,887 Likes on 1,226 Posts
Originally Posted by peteldoo
will theses wind fork deflectors stop air flow to the back cylinder thanks
I had them on my last three bikes. I measured temps with the Power Vision and there was virtually no difference. The PV measures temps at the rear cylinder so no worries as far as air flow.
  #2882
Old 05-24-2021, 05:15 AM
Morish's Avatar
Morish
Morish is offline
I’ve had no issues with temps.
  #2883
Old 05-24-2021, 05:28 AM
peteldoo's Avatar
peteldoo
peteldoo is offline
Stage IV
ok thanks was looking at get some for my 2020 heritage but it gets warm in australia
  #2884
Old 05-25-2021, 08:40 AM
edalfa's Avatar
edalfa
edalfa is offline
Originally Posted by SilverSpear85
Hi everyone, I just purchased a set of Straight jacket handlebar from KST kustoms and when I tried to fit the handlebars on the stock risers, the clamping area was a bit narrow. Anyone else run into this issue? If so, what was your workaround? New risers? filed down the edges of the clamp area? Any insight is appreciated.
I put the 12" Straight Jacket on my 20 Heritage. No issues at all. Great handlebars!
  #2885
Old 05-25-2021, 09:12 AM
Rebel420's Avatar
Rebel420
Rebel420 is offline
is it possible you bought a set designed for springer front end? Some bars designed for springers have a narrower clamp area.
  #2886
Old 05-25-2021, 04:41 PM
S0L01984's Avatar
S0L01984
S0L01984 is offline
Originally Posted by yamon
Solo1984
Can u post a pic of rider and passenger seat from the side? I am wondering if teh passenger seat slopes toward the rider like a sundowner pillion does.
Thx
I don't have a pic but I can tell you it doesn't slope like the sundowner. I originally had the sundowner and that slope is the reason I got rid of it. Another option would be the pillion of of an older heritage.
  #2887
Old 05-27-2021, 10:19 AM
yamon's Avatar
yamon
yamon is offline
Thanks
  #2888
Old 05-28-2021, 02:33 AM
Hedonism's Avatar
Hedonism
Hedonism is offline
Originally Posted by FrankEV
The Grasshopper back rest is nice and very easy to install. Unfortunately, I had put a Reach Seat on to lower me and move me forward and the back portion of the Reach seat is much thicker (front to back) than the stock seat, making the backrest unusable. I could have saved you a few $$$.
Would still like to have a backrest, but I guessing it will have to be some kind of custom made unit. Tempted to have a bent plate made to weld onto the Grasshopper to make it extend further forward.
hi, I'm thinking to swithc from my LR to the Heritage, but I need a reach seat due to the forward control on the heritage; which reach seat did you put? and does it fit with the passenger pad? thanks
  #2889
Old 05-28-2021, 03:24 AM
Hedonism's Avatar
Hedonism
Hedonism is offline
Originally Posted by HogryderFL
I see you have the reach seat with the hopper backrest. Did you have to modify the backrest to have it work with the reachseat? Also how comortable is that seat? Around town and longer rides?
hi, is the seat combo "Reach Solo De Luxe Style + Touring Passenger Pillion Softail/deluxe style"?
thanks
  #2890
Old 05-28-2021, 03:33 AM
Hedonism's Avatar
Hedonism
Hedonism is offline
Originally Posted by luckyboy06
Hello, I am a shorter rider and I had an issue with shifting.
I took a stock shifter to a machine shop and they shortened the shifter and tapped a new peg hole.
I then purchased a longer shifter for the rear.
The shifter pegs are from Thrashin' Supply Company.
I hope this helps a fellow rider with short legs.
Thank you,
Lboy06
Short front shift lever and longer rear shift lever.
Rider's view.
Stock length vs. machined length.
Machined by hand and you could not see the cut area.
what abt the rear brake pedal?
The following 2 users liked this post by Hedonism:
Axedude (08-23-2023), cobalt07 (05-16-2024)
Quick Reply: The Everything 2018+ Heritage Thread
