The Everything 2018+ Heritage Thread
#2006
I took a look at how the leather is attached to the plastic saddlebag on my 2018 Heritage and the seams are not glued to the plastic. They appear to be mainly riveted through metal brackets to hold the leather to the bag. The corners of the leather are NOT glued to the plastic bag. This allows the water to enter the space between the plastic and the leather which then gravitates to the bottom of the bag by way of the small hole the factory placed at the bottom of the plastic bag. While at the dealer, I told the service manager about this issue. So, she had the prep guy wash a new Heritage and we saw the water move past the leather at the corner seam and through the hole at the bottom of the left bag. We ended up with about 2 inches of water in the bag. Since the bike leans to the left, that bag is the one to get the water. So...not sure Harley will address this or not, but I plan to plug the hole. I also believe placing a drain hole in the leather will allow any excess water to drain out of the leather and also reduce the chance of that area mildewing in the future. If my memory serves me right, I seem to remember that is how my wife's 2007 Road King Custom leather wrapped bags were fabricated at the factory.
#2007
Question for those of you who have installed passenger floorboards, especially with saddlebag guards. I had the dealership install these but I’ve had to remove them due to some exhaust work. I’m reinstalling them and have run into something a little suspect. I didn’t receive any spare parts when I bought the bike but it seems there may be two lengths of mounting adapters available. I’m not sure if these are model specific or if the kit comes with both.
On the left side, they used the longer adapter as you can see in the pictures. The right side is the shorter one. I do have the saddlebag guards installed so that muddles up the instructions a bit so before I show up with the pitchfork at the dealership I want to make sure I know what I’m talking about.
The floorboard mount is not staying in place as I tighten it. It’s trying to rotate which is what led me to look into this a bit. I don’t know if the longer adapter will have a different face or clocking mechanism or what.
Anybody have any insight?
Left side, longer adapter, seemingly accurate based on the instructions as far as I can tell.
Right side adapter, shorter than left side adapter.
Screenshot of instructions. Again kind of confusing because of the saddlebag guards.
Clearance under right side mount with shorter adapter installed.
Right side shorter adapter installed. Does not keep the mount from rotating when torqued down.
#2008
BTW can you send pix of your bike with these installed maybe whole bike and half of the rear of the bike. Want to see how it looks like as I was wondering about these boards.
#2009
Based on what I think longer adapter should go to the right which make sense due to more clearance because of exhaust. I feel this kit had some extra parts that are not used as these are for other models so chances are they discarded these. Not sure how is proper set up on left side as i dont see whole instruction. I dont trust anyone with my bike, especially sloppy dealers. The things they do man.
#2010
So something else is needed? Wonder what they messed up? Thanks for posting pix after installing I really want to see this as maybe I will go this route
