Ignition lock question
So the other day we took off for a short RV trip. Decided to lock the forks and ignition. Turned forks to far left, turned ign switch to far left and locked with key, no issues.
Got home a few days later, and too me about 10 min of farting around, jiggling the key, etc, till it finally unlocked. Did I miss something, or is this a known issue that needs to be corrected?
This is on my '14 FLHTCU.
Pin extended.
Pin retracted.
Pin extended into steering neck recess.
The following 2 users liked this post by barneyboy:
chopper_man (10-13-2020),
GalvTexGuy (10-13-2020)
I don't use my fork lock anymore for this very reason. Earlier this year my handlebars slipped in the riser, so obviously I had to remove the ignition switch to gain access into that area. Well, the switch was a b**** to re-install properly. I ended up being able to get it back on well-enough to ride to my indy who had that special little ignition switch alignment tool.
Thanks Baneyboy
The pics really help. We did another overnite run yesterday. Before leaving I tested it again, and all seems well. Maybe it stuck from lac of use before, not sure, but seems to work fine.
twincam
That seems like s totally different situation, to me. I am not removing mine, just using the extra bit of security, incase someone decided to try and help themselves to my bike while I was away. Personally, I like the extra layer. The only bike I ever had stolen, was a '73 CB450, that I bought new. Parked st a "sort of" park n ride, and decided that once not to lock the forks. When I got back to it that evening, I was without my new bike.
I no longer leave my bikes places like that, or leave them very long without the forks being locked. I know it doesn't stop the best of them, but every little bit helps.
twincam
Twillis
09-23-2012 08:21 PM
user 5342924
10-11-2008 03:39 PM
