****New clutch recall issued 9/8/14****
#121
Mine has been that way since day one. My 04 Roadking (cable actuated) was the same way. Didn't want to roll if in gear, clutch in. Are you sure it's a new thing?
#122
Not 100 percent - but it was definitely more difficult than normal - enough that I thought "something is different here". I even stopped and looked to see if there was something under the tires. That coupled with the fact that it wanted to creep at the light, and that it is "clunking" more when shifting gears makes a lot of sense. Already called the dealer and he asked me to trailer it in Saturday morning.
#124
He mentioned it is just a new plunger for the clutch actuator. Despite being a simple device I'll admit I'm not very versed on the internal guts of the hydraulic clutch (all of mine have been cables to this point) but they acted like it was just a single quick replacement of this lone piece.
#125
#127
The plunger is what they replaced on the recall last October. I was hoping they had a whole new master cylinder this time. Hopefully your dealer didn't do last year's recall on your bike by mistake since the new parts for this recall aren't suppose to start shipping untill the 15th.
#128
They came out with a new master cylinder with an "A" revision in the part number last spring. Maybe if you have the "A" revision you only need the plunger and those of us with the original version will get a whole new master cylinder. They quit rebuilding the master cylinders that failed after the rebuild and start replacing then with the new one last spring. I'm sure they will do whatever is cheapest to get the NHSTA off there back.
#129
