Seat Screw
Seat Screw
I don't know if it's just me, but I have no problem removing the seat screw, it's trying to get the darn screw back in that gives me fits. My hands just don't fit in the small area very well. I can't count the number of times I had to use a magnet to fish the screw out from under the seat. It seems that a magnetic screwdriver won't hold the screw very well. I put a very tiny drop of super glue on the head of a phillips screwdriver and then put the screw onto it. The screw is held in place long enough to get it started and then comes off as your turning it in. Sounds kind of dumb, but it saves me a lot of aggravation.
You can also open the Tour Pack to get more room.
I replaced it with the removable quick-release seat hardware thumbscrew that I had leftover after trading in the Road King.
http://www.harley-davidson.com/store...t-hardware-kit
Since you don't see it I'd guess a local hardware place would carry a cheaper alternative that isn't quite as flashy. Between this and removing the seat strap I don't need tools to pull it off while on the road. Neither does a thief I suppose but I'll take that chance.
I put on the Speed Tab from Kury.
I have 3 different seats that I interchange, and this only takes a second.
http://www.kuryakyn.com/Products/848/Speed-Tab
I bought the Harley Thumbscrew for $20. My Indy didn't tighten it all the way and it fell off. I bought a whole bag of stainless steel bolts for $3, and some lock washers, now I take it on and off with a wrench.
I originally bought a 3/4 inch screw, but it was too long. I was concerned that it might hit the tire so I used a 1/2" bolt.
The other benefit is that the screw is held in place by the security screw driver tip so installation is a breeze. Cost $1.50 in stainless at the hardware store.
