Just finished putting 10 3/4" KST Mayhems on my 2014 Ultra Limited. Stock brake and clutch lines, had to clip the wire ties holding them on the risers. Used the Harley plug-n-play wire extensions. Skipped the heated grips.. Would have required cut-n-solder extensions, and looked like too much work... And I live in Florida anyway, LOL. 2 hours taking it apart last night, 3 hours putting it together tonight. Tip: get some chain, like the kind they use on dog leashes, with some weight to it. Run that thru the bars and then pull some weed whacker line back through. Use that to pull the wires. Run all the weed whacker lines you'll need at once. Pics coming once it's daylight.
OK.. here's the first pics... which are lousy... one in the garage last nite with the work light, one this morning with the sun at a lousy angle.... Will try to get better pics later....
