2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
lets see the Apes!
Old 04-11-2015 | 09:47 PM
dmize's Avatar
dmize
Originally Posted by devilmoon
12" vindiktas
Man those look good... but dam are they $
  #272
Old 04-12-2015 | 12:41 PM
Womack's Avatar
Womack
Originally Posted by DD Dont
Dumb question, maybe.
I put new grips on the bike not that long ago.
If I switch bars this winter, should I just factor in a set of replacement grips, or will my Kuryakyn ISO grips be salvageable?
You can get a new rubber insert for your left grip.
You can order a replacement thru Kuryakyn.
Womack
  #273
Old 04-22-2015 | 06:32 PM
FLSpringerSE's Avatar
FLSpringerSE
Angry
Originally Posted by junglejoe
Anyone running these jsrbaggerbarsl
Love the look and spec's of these bars...have tried both email and phone to order a set and have not gotten a response. Going on day 5.
  #274
Old 04-29-2015 | 05:36 PM
z33k's Avatar
z33k
6th Gear
Default Gunner B - KST 10 3/4" on 2014 Limited
Originally Posted by Gunner B
KST Kustoms 10 ¾ Mayhems
Gunner, did you do the install on these? Please PM or otherwise contact me.
Zeek
  #275
Old 04-29-2015 | 09:06 PM
junglejoe's Avatar
junglejoe
Originally Posted by Caddywompas
Have a 2014 FLHXS. Trying to find bars with a 4" to 6" pull back 12" high. Any suggestions please?
I "think" the Yaffee bars you can get a 6 or 9 inch.. thought I read that somewhere. I was wanting the same thing, but the 9 inch is perfect on the Yaffee Monkey bars I have on mine!!
  #276
Old 04-30-2015 | 05:33 PM
matt76cmich's Avatar
matt76cmich
I can finally post in here. 14" KST Mayhem Bagger Bars with stock brake and clutch lines. I suggest the 15" Namz extensions if you use them and the photo thread on here helped a ton. I guess only tip I might have is use cable lube when wiring. I tried without it at first and after using it I wish I had just started with it.
  #277
Old 04-30-2015 | 07:53 PM
Shane Grimstead's Avatar
Shane Grimstead
2015 SGS w/14" Vindikta Bars
  #278
Old 04-30-2015 | 09:35 PM
z33k's Avatar
z33k
6th Gear
Default KST Mayhem on 14 Ultra
Just finished putting 10 3/4" KST Mayhems on my 2014 Ultra Limited. Stock brake and clutch lines, had to clip the wire ties holding them on the risers. Used the Harley plug-n-play wire extensions. Skipped the heated grips.. Would have required cut-n-solder extensions, and looked like too much work... And I live in Florida anyway, LOL. 2 hours taking it apart last night, 3 hours putting it together tonight. Tip: get some chain, like the kind they use on dog leashes, with some weight to it. Run that thru the bars and then pull some weed whacker line back through. Use that to pull the wires. Run all the weed whacker lines you'll need at once. Pics coming once it's daylight.
  #279
Old 05-01-2015 | 06:15 AM
frankb's Avatar
frankb
Default mirror
I am in the market for new mirrors ... What are your mirrors? They look real good. Thanks... Frank
QUOTE=jma100;13890200]14" Yaffe MBB. 14 Ultra Limited CVO.
[/QUOTE]
  #280
Old 05-01-2015 | 06:18 AM
Seventy4blazer's Avatar
Seventy4blazer
Originally Posted by owensmech
Which makes sense, then theyre only manufacturing one wiring harness for all touring bikes, to save from making so many iterations, like car companies do.
I wish that this were the case...
Main wire harnesses are different on all of the touring bikes.
Quick Reply: lets see the Apes!
