2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
CVO Dash Trim Install
Old 12-26-2014, 04:28 PM
BillNich's Avatar
BillNich
BillNich is offline
Originally Posted by Brian MD.
Thanks, I ordered the inner fairing right from Harley store here in Maryland.
I am also in Maryland....what Harley store did you use?
  #62
Old 12-26-2014, 05:16 PM
Brian MD.'s Avatar
Brian MD.
Brian MD. is offline
Harley Davidson of Baltimore. They offer 20% off parts and 20% labor in November and December.
  #63
Old 12-27-2014, 08:19 AM
BillNich's Avatar
BillNich
BillNich is offline
Is the inner fairing a do it yourself kind of job or is it best done by the dealer?
  #64
Old 12-27-2014, 12:42 PM
HarleyguyUltra2011's Avatar
HarleyguyUltra2011
HarleyguyUltra2011 is offline
Easy job you just need to make sure the inner fairing is clean the trim uses double sided tape . Using some 3M activator for double sided tape will help it stick better .
  #65
Old 12-27-2014, 01:00 PM
BillNich's Avatar
BillNich
BillNich is offline
Sorry...I meant the actual inner fairing not just the trim.
  #66
Old 12-27-2014, 07:06 PM
firefighter156's Avatar
firefighter156
firefighter156 is offline
If you are handy it can be done by you but it can be pretty intimidating. There is a thread on this site that will walk you through it step by step. Use the search function and you will find it. Good luck.
  #67
Old 12-28-2014, 07:10 PM
Brian MD.'s Avatar
Brian MD.
I let the dealer do mine. Tool back the other day. Since the handlebars I put on the bike are rubbing against the fairing. They are going to trim the fairing for the larger bars.
  #68
Old 12-28-2014, 07:29 PM
BillNich's Avatar
BillNich
BillNich is offline
how many hours did they charge you for?
  #69
Old 12-28-2014, 08:40 PM
Brian MD.'s Avatar
Brian MD.
I'm not exactly sure Bill. I had alot of stuff done. 23 hours worth of labor. Call and get a quote. They offer 20% parts and labor in November and December. I saved a good bit there.
  #70
Old 01-05-2015, 02:04 PM
hbsoldier3's Avatar
hbsoldier3
hbsoldier3 is offline
Finally got the ***** to install my trim pieces
Quick Reply: CVO Dash Trim Install
