CVO Head Unit
CVO Head Unit
So can someone share the differences between the premium head unit and the CVO premium head unit. I see the new SG CVO has a 600 watt system and in looking up parts, as in speakers and amps, I noticed that the head unit for that bike is listed at 2400.00 dollars vs 1850.00 for non CVO model and they are different part numbers. Curious!!!!
Someone else said the SG CVO comes with a 600 watt system. Looking at the website, it looks like the same 300 watt system found on the other bikes (75 watts x 4 channels) http://www.harley-davidson.com/conte...#!key-features
To be honest, the only difference I have seen in the actual radios is the startup screen has a CVO opening screen. Other than that, the amp and XM radio are the only obvious differences I've seen.
I think that the head units are the same, but the sum of the parts makes it a "CVO Unit". The head unit only delivers 25w x 4 speakers, but you can add a Boom Audio amplifier that disables those and provides 75w x 4 by itself. The other missing piece of the puzzle between the Limited and the CVO is SiriusXM. The module is included on the CVO, but not the Limited.
You're looking at $1000 for the amplifier with upgraded, non coaxial speakers
And $400 for the SiriusXM module
Plus labor if you're not the adventurous type...
I know that the SiriusXM module is plug and play, but I'm not sure about the amp. That may require a flash.
P.S. I do understand that for some custom applications, that Digital Technician flash device can allow you to use the amp AND some of the 25w channels on the head unit. I suspect the dealer did this to my friends bike when he had saddlebag speakers installed. He has 6 speakers and only 4 channels and I sure hope they didn't run in parallel and cause impedance issues.
northerntech
06-19-2017 05:35 PM
jeff53404
2014-2023 Touring Models
11-04-2016 08:15 AM
