2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Electra Glo saddlebag lights
Old 06-09-2015, 06:44 PM
Dsm Limited's Avatar
Dsm Limited
Dsm Limited is offline
Received 9,611 Likes on 3,247 Posts
Originally Posted by Freesince1903
I only have one problem with mine. When I take my tour pak off my blinkers on dash blink fast but are blinking normal on the outside. When I plug the tour pak back in they work fine.
Turn the ignition on, bike not running, turn on hazard lights for several minutes. Turn off hazards and check operation. This should get dash turn indicators from flashing fast.
  #32
Old 05-11-2019, 09:06 PM
airmorris9's Avatar
airmorris9
airmorris9 is offline
3rd Gear
Very helpful. Would not have thought of that. Thanks for posting. Takes some work but doesn't scratch the saddlebags. Brilliant
  #33
Old 05-11-2019, 10:25 PM
Ssitruc's Avatar
Ssitruc
Ssitruc is offline
Received 1,033 Likes on 706 Posts
Just noticed how old this was... sorry.
  #34
Old 05-12-2019, 08:31 PM
talkingrock's Avatar
talkingrock
talkingrock is online now
It’s normal that’s the way function , I really like mine 2 blinker are not enough light on the rear of the bike
  #35
Old 05-13-2019, 08:12 AM
gigihurt's Avatar
gigihurt
gigihurt is offline
This is due to an imbalance. Cars do it when one light is out on either side.
  #36
Old 05-13-2019, 09:38 AM
Ssitruc's Avatar
Ssitruc
Ssitruc is offline
2 1/2 yrs ago I had HD's ElectraGlo Keystone rear blinkers installed. For entire time the indicator blinks fast if the tourpak is off the bike. I have tried everything I have heard of to get the indicator to "normalize"... everything from the "load learning" thing, all kinds button sequences, and even had both dealers near me give it a shot while having tires or something else done. Nadda... I don't even worry about it anymore, the actual signals are blinking normally and that's what's important.
Curious thing though, when the bike arms/disarms the security system, the the ElectraGlo blinkers do not blink. So, if the tourpaks off, only the front blinkers blink on arming/disarming. If tourpak is on, the tourpak's blinkers blink also. Of course when the tourpak is off the bike, and it arms/disarms, it will kick two codes (B2151 & B2156 I believe). No codes with the tourpak on, because its blinkers blinking upon arming/disarming. Theres also another quirk, it involves using the hazard flashers and what position the ignition switch is in (acc-on-off), whereas in one position (off, I think) only the fronts will blink if the tourpaks is not on bike...
I have been meaning to verify the pin out of the tourpaks light's 6-pin connector -vs- the brake light's 6-pin connector (the one that the ElectraGlo's harness plug-n-plays with) and see what/if there is something different, but have not ever got around to it. BTW, a neighbor has the same lights and his does the same exact things. We installed his lights, and a local dealer had installed my lights while doing a bunch of other work when bike was new.
  #37
Old 05-13-2019, 03:14 PM
rcn1963's Avatar
rcn1963
rcn1963 is offline
If I recall correctly, there was a flash setting to determine if the saddle bag lights acted as turn signals only...or turn signals and brakes. I recall having to have them change that, but I don't remember if it was on my 14 SGS, or the current 16 UC. I had the saddle bag lights put on both for the visibility.
  #38
Old 05-13-2019, 08:49 PM
Ssitruc's Avatar
Ssitruc
Ssitruc is offline
Not for sure what you were responding to... but in my situation, my keystones are run/brake/turn lights, and function as such, except the quirks mentioned above... which make the quirks even more weird.
  #39
Old 05-13-2019, 11:36 PM
rcn1963's Avatar
rcn1963
rcn1963 is offline
I was just saying I think there is a flash that alters how the saddle bag lights work if anyone is interested. In the discussion about how the saddle bag lights work, I didn't see anyone mention it. And if anyone is experiencing strange behavior, it's also possible something got corrupted that a flash might fix.
  #40
Old 05-14-2019, 09:10 AM
Ssitruc's Avatar
Ssitruc
Ssitruc is offline
I got you, and I was told that by the local dealers also... but both times I got it back nothing had changed. I just need to get around to looking at the plug that the tourpak's lighting connects to and compare it to the brake light connector under the seat that the Keystones plug into and see what, if any differences there are. Just hasn't been a priority yet.
Quick Reply: Electra Glo saddlebag lights
