2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Street Glide Rear Fender On Ultra Limited
Old 08-23-2014 | 05:17 PM
HJP's Avatar
HJP
Question Street Glide Rear Fender On Ultra Limited
Has anyone done this on a 2014 and if so how does the turn signals work since on the ultra they are on the tour pak.
Thanks
Old 09-06-2014 | 09:24 PM
antheriot's Avatar
antheriot
6th Gear
The dealership changed mine out before I bought it. They installed the SG fender with the docking hardware in order to make my tour pack detachable (before the kit was made for the ultra from HD). They installed stock SG turn signals and brake light. Pics are below with the tour pack on and off. I also installed some saddlebag lights as well.
Old 09-07-2014 | 07:16 AM
SafetyMan's Avatar
SafetyMan
That looks good....
Except for the black antenna hole plugs on the filler strips and the black nubbins on the antenna mounts on the TP.
Old 09-07-2014 | 09:17 AM
p51bombay's Avatar
p51bombay
Thanks
If you use the 2009 style fender (same as 14 CDN models) you can keep your stock taillight and add the bullet lights..........but not everyone likes that look.
Originally Posted by SafetyMan
That looks good....
Another reason for vivid black - filler plugs almost disappear. TP antenna mounts can be removed if you're using hidden antennas and install some (almost) flush plugs like so.
Old 09-07-2014 | 09:22 AM
SafetyMan's Avatar
SafetyMan
I would like to see them, or someone, come up with a paintable plug.
Those little caps look a lot better, IMHO.
Old 09-07-2014 | 05:31 PM
MikeyTX's Avatar
MikeyTX
Agree, it would be nice if the MoCo would come up with body color hard plastic plugs for the fender skirt rather than the soft rubber plugs.
Old 11-21-2014 | 10:57 AM
PaUltraharley's Avatar
PaUltraharley
4th Gear
Default antheriot
Anthony Can you tell me which dealer did your work.
I just bought the fender and my dealer has no clue
my number is 215-847-5111 or email richl@merchantchoiceusa.com
Thank you in advance
Old 11-21-2014 | 11:01 AM
PaUltraharley
4th Gear
Anthony would you please tell me the dealer that did the install?
My dealer has no clue.
I just bought a new street glide fender and want to do the same thing you did.
Also do the tour pack lights and the fender lights all work at the same time or do you have to unplug one or the other?
thanks so much Rich
Phone 215-847-5111 or email me please richl@merchantchoiceusa.com
Old 11-21-2014 | 12:54 PM
N U K E's Avatar
N U K E
I installed a street glide fender on my 14 Limited. It was plug and play.
I bolted it on plugged it in and everything works, with or without the tour pack.
Old 11-21-2014 | 01:46 PM
PaUltraharley
4th Gear
Nuke can you cal me??
I just have a few questions.
215-847-5111 Rich
When you say its plug and play. The ultra fender only has the running light and the break light. is there a Y harness you need to tap into the the tour pak or something.
Quick Reply: Street Glide Rear Fender On Ultra Limited
