2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Street Glide Rear Fender On Ultra Limited
Old 11-21-2014 | 01:56 PM
PaUltraharley's Avatar
PaUltraharley
4th Gear
Originally Posted by N U K E
I installed a street glide fender on my 14 Limited. It was plug and play.
I bolted it on plugged it in and everything works, with or without the tour pack.
Nuke was there a plug opened that you plugged into or was it the same one that the Ultra fender was plugged into. My dealer seems to think they are different because the street glide has the turn signals on the fender. Can someone take a min and call me. I have my bike apart??? 215-847-5111
Thank Rich
Old 11-21-2014 | 05:42 PM
Xb9rumble's Avatar
Xb9rumble
Originally Posted by antheriot
The dealership changed mine out before I bought it. They installed the SG fender with the docking hardware in order to make my tour pack detachable (before the kit was made for the ultra from HD). They installed stock SG turn signals and brake light. Pics are below with the tour pack on and off. I also installed some saddlebag lights as well.
Did you get a new front fender as well? That's a clean looking ultra.
Old 11-21-2014 | 08:04 PM
N U K E's Avatar
N U K E
Here's a picture of mine.
Old 11-22-2014 | 01:52 AM
antheriot's Avatar
antheriot
6th Gear
Nuke,
Thanks, Stock front fender. If anyone finds a front fender skirt to replace the stock tin foil one for the 2014 let me know.
PaUltraHarley
HD of Dallas did the install.
When the tour pack is on all of the lights work for brakes and blinkers. When I remove the tour pack I sometimes have to turn on the the hazards for about 20 to 30 seconds for the computer on the bike to reset. Otherwise the indicator lights on the dash blink very fast indicating that there is a bad light even though all of the lights are working.
I was looking into removing the antenna nubs on the tour pack but i found that they make good helmet hangers when we stop.
Old 12-08-2014 | 09:06 AM
Magnut1's Avatar
Magnut1
I just did the swap on my 14 roadking, installed 14 streetglide front and rear fenders. The only problem I had was the brake lights didn't work. Everything else did. Had to go to the dealer and have them change the settings in the BCM, took about 20 minutes and $50 but they work now. Am happy with the look. Found both fenders on ebay from 2 different people and they were both my color and had the correct pinstripes.
PTRider
10-13-2013 08:29 PM
Guzz
02-06-2013 07:32 AM
Valkyrie
02-13-2010 09:07 PM
MonsterRK09
01-22-2010 12:18 AM
lock55
07-30-2009 03:16 AM
Quick Reply: Street Glide Rear Fender On Ultra Limited
