Does anyone know if I can order the rear fender fascia (p.n. 59500107) and associated lights and wiring for a '14 CVO Road King and bolt it to my '14 Street Glide rear fender? If so, will it bolt right on or are modifications needed? Thanks
I pretty sure it's plug and play but you should check with your dealer. I have the pre 14 light setup on my 14 and it is not plug and play. You will also need to do something with the leftover lightbar holes in your fender or change to a CVO fender.
Part Number 59500246 for the Kit... all it needs is paint
