need advice
Maybe I should have checked the oil but I would not expect a $25,000 new motorcycle with only 2,500 miles to use a quart of oil much less 3. I have owned several motorcycles of varying brands over the years and none of them has used enough oil to measure. I have owned air-cooled VWs, which would be the closest thing I could equate to a Harley engine in a car, that used less than half a quart of oil in 5,000 miles and they had 40 year-old engines.
Now I'm not trying to slam you or start an argument but I have learned things the hard way before. I just hope you take it as a learning experience. Hopefully the dealer will do right by you and take care of everything.
Well, I'd be upset if it was determined my new bike ran with barely any oil in the crankcase, especially as the result of a service department error - but I'll really be surprised if you get a free extended warranty, much less a free engine. I'd think it be more likely you'd be able to get some kind of a discount on the ESP if that is what you wanted. Certainly, if the dealer didn't work with me I'd let the MoCo know, & I might do it anyway to have it on record that I logged a complaint.
That said, the folks here recommending you pull the dipstick regularly are correct. I'll generally check mine when I buy fuel at a minimum; do the same in my cars. FWIW, I wouldn't own a motorcycle without also owning a couple of torque wrenches too.
jetwrench450
Screamin Eagle CVO Models
11
05-09-2011 07:02 AM
