Adjusting Headlight?
Ok, my headlight needs to be aimed up more along with my spots, I'm tired of looking at the ground. I'm usually pretty good at this but I cannot figure out how to adjust the headlight, I went searching for a screw or screws and can find nothing. For the spots I guess I need to notch a socket for the wire... How the heck do you adjust the headlight???
As the manual states, 5/32" ball end hex. Top center cutout is for up/down adjustment, side cutout for side to side. If you don't have the ball end, use a regular hex end and will then be easier, especially without the ball end wrench, to just remove the trim ring (yes, you can do that quite simply in about ten seconds-remove bottom screw and rotate ring a few degrees to the left and it comes off easily) and adjust, then you don't have to push in on the gasket to find the screw. Turning the wrench clockwise will raise your headlight.
It can be done without removing the headlight ring but it only takes 15 seconds to remove it and makes it so much easier to adjust the headlight. Once the top adjusting screw bottoms out the light will more than likely still not be adjusted up enough. That's when the two side adjusting screws have to be adjusted out. Also, there is not much adjustment to move the spots up. It's a little different mount from the past. I guess it's to keep from adjusting them into oncoming traffic since the LEDs are so bright.
Yep!......among all the trials and tribulations of the new rides...mostly good stuff though
BTW, I ended up going a couple turns in on the top screw and the night rides are pretty good, especially with the passing lamps on with bright so gonna leave it there for a bit and see how she goes. Buddy of mine screwed his all the way in as the previous post describes and still wasn't where he wanted it so YMMV.
It's impossible to adjust the HL without removing the ring. I tried it for 20 minutes last Fall. Finally called the dealer and he told me what to do. Turned mine all the way up. The dealer would not set the aux lights to be on all the time. So my high beam is useless except to signal somebody.
