2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
First gear whine
Old 07-26-2014 | 08:08 PM
gs46's Avatar
gs46
Default First gear whine
Anyone else have a first gear whine on downshift,,,,2014 Ultra FLHTCU
Old 07-26-2014 | 08:18 PM
mikeman54's Avatar
mikeman54
First gear whine all the time.No answer why
Old 07-26-2014 | 08:28 PM
Mikula's Avatar
Mikula
same here. figured it was normal, never thought to ask about it
Old 07-26-2014 | 08:54 PM
RK_2014's Avatar
RK_2014
Yup - same here
After a while I am now using it to ensure I am in first when down shifting thru to a stop
AFAIK this is normal
Old 07-26-2014 | 10:32 PM
tpcowfish's Avatar
tpcowfish
Yep, odd huh
Old 07-26-2014 | 10:45 PM
Smittyjf's Avatar
Smittyjf
its the helical cut gears that are your 1st gear. That's why they whine
Old 07-26-2014 | 10:46 PM
MajorThom's Avatar
MajorThom
Same here. It's not as bad as some others I've had, so it doesn't bother me.
Old 07-26-2014 | 10:48 PM
OCD's Avatar
OCD
Yep. My FLHXS also has the first gear whine. Dealer says its normal. The dealer also said it was normal to have problems shifting into first. (Just let the clutch out a little).
Old 07-26-2014 | 11:41 PM
biglipps66's Avatar
biglipps66
I love the sound of it, completely normal and yes its the way the gear is cut
Old 07-27-2014 | 07:22 AM
Campy Roadie's Avatar
Campy Roadie
Veteran: Marine Corp
It's the opposite. First gear is straight cut (spur), the rest are helical*. Helical gears are quieter than straight cut but impart side loading (lateral thrust) on the shafts. Spur gears are capable of greater loads like moving a heavy motorcycle from a dead stop.
*Some years of HD transmissions have a spur gear for 5th. HD changed that when customers complained about the noise.
Quick Reply: First gear whine
