Nav software update fails
Anyone get this error message while trying to update the NAV software?
It asks if I want to apply the update, I say yes, The update runs for a bit and then produces the error message. Anyone get past this?
I found on page in french that explains how to get past the error but google translate isn't the best... Here's the french page: http://www.passion-harley.net/t52054...re-et-utiliser
Error: Nav_sync_NoNavContent
Here's what I did:- attached an empty USB stick & did an Settings->Navigation->Export
- installed Navi software on PC
- inserted the USB stick into the PC
- Got the message "There is an urgent update" and followed the instructions to load the update onto the USB stick
- re-attached to the bike and turned turned ignition to accessory
FWIW - A couple days ago I ran the NaviExtras Toolbox. It checked, found & installed an update to the Naviextras Toolbox itself. When I then connected my USB stick with my Nav system export file, the Toolbox gave me a message saying my system image file was up to date.
Original attempts gave the same result others are reporting. I've concluded the most recent Toolbox software update has finally been updated to reflect the correct production version of Nav software in the bike's Infotainment system. Note, this is only my conclusion & may not reflect the actual reason I got the system is up to date message.
I hate to rant but paying for a map update seems so last millennium. You can buy a garmin for your car for $150 and it comes with lifetime map updates. We spend, what, $2K and get a 2 yr old map and then have to cough up $150+ to buy a year old map. I'll probably just live with the delivered map. Mostly use it for driving to unknown back roads and they are probably pretty stable. Plus I can always use my phone in a pinch
In your steps to install, I didn't see that you unzipped the download file. Download the file from HD site, unzip it on your pc, tranfer unzipped file/folder onto your flash drive then put flash drive into your bike's usb port then go through the install process. You may have already done this, if so that's all I got. I had no problem updating software.
The standalone GPS market is dying, being quickly replaced by built-in vehicle systems on one end and smartphones on the other.
Very few people have the need for a standalone GPS unit today.
The in-vehicle systems have you by the *****, what are you going to do, rip it out and buy a new one or pay $100-$200 or an update? All my cars are the same way.
Sent from my iPhone using IB AutoGroup
