2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
x m radio reception and popping noise on 2014 FLHTKSE
Old 10-08-2014, 07:49 PM
hbsoldier3's Avatar
hbsoldier3
hbsoldier3 is offline
Wow, I am surprised how many riders are having trouble with XM reception. I installed the module today,and have great reception; even in the twisties. Maybe I am one of the lucky ones.
Old 10-18-2014, 10:12 PM
codpilot's Avatar
codpilot
codpilot is offline
Default All depends on where you are
Not sure if these units work the same way as my old XM but my old XM unit had both a sat and Radio component.
Now with mine in some cities even in tunnels no drop. In others dang thing can't hold a signal if you connected the sat signal via cable.
So yah in my travels - big sky country works well. Plant a bush near it and poof all achy breaky signals.
So yes rather disappointed.
Old 10-19-2014, 08:55 AM
01XLH's Avatar
01XLH
01XLH is offline
Some cities have ground based repeaters, that might explain how you're getting the signal in a tunnel, but boy the stars would have to be aligned perfectly for that to work.
My XM is not the HD module add-on, I move my receiver between home, car, bike and work.
Does the HD module give you the option to "check signal"? On my unit I can tell if I'm getting the signal via satellite or local repeater.
Old 10-19-2014, 09:38 AM
rickyj1962's Avatar
rickyj1962
rickyj1962 is offline
I've had my HD XM now for two months now, no issues. Every now and then I'll go under an overpass and it'll cut out but no big deal.
Old 10-19-2014, 09:56 AM
GSHOG's Avatar
GSHOG
GSHOG is offline
I was having XM reception problems on my '14 Limited and relocating the antenna to the top of the inner fairing made a big difference. I still lose reception on occasion but not nearly as much as before moving the antenna.
Old 10-19-2014, 06:46 PM
YPD485's Avatar
YPD485
YPD485 is offline
It will show up to 3 bars if its getting a strong signal.
Old 10-19-2014, 06:58 PM
01XLH's Avatar
01XLH
01XLH is offline
Opps my mistake.
On my receiver, it shows me both the ground-based on satellite signal strengths.
Thanks
Cheesehead_13
Audio Systems
12-16-2017 11:25 AM
drspencer
12-02-2014 08:31 PM
tdgriff
Audio Systems
10-21-2014 12:17 PM
glide2005
Audio Systems
02-05-2014 02:51 PM
ricaroo
05-08-2007 04:40 PM
Quick Reply: x m radio reception and popping noise on 2014 FLHTKSE
