rider backrest for flhxs
The adjustability moves it fore and aft. I use the adjustment frequently to change positions on longer rides. I like to lay it back a bit when using the highway pegs. Having on-the-fly adjustability is very nice.
Maybe you feel the need or slouch as time goes on, I do not. Does it make you wrong for installing the ugly lever, no, does it make me wrong for not installing that ugly lever, no
Been on long rides and have never felt the need to adjust it. I installed one on a friends bike the same way and with the same results.
I added the adjustable mount and the comfort backrest to the stock seat. I like the rest but it sticks up out of the seat further than I like and with the black metal exposed between the rest and the seat doesn't look finished. On another thread someone suggested having a section cut out of the rest and re-welded to reduce the exposed area. I'm considering doing so. Unless you are really, really tall there should still be plenty of adjustment available. I went for a long ride this weekend after installing and really like being able to adjust the angle. If you go with the adjustable you have to be careful about the placement of the plastic piece they give you to mount under the seat. It is supposed to keep the seat from wearing out when being adjusted. If you mount it too low the mount catches on it. I also had an issue with the clip nut stripping out that holds the lever for the cable and had to add a nut on the backside to mount it.
