The SE 211 cams like more compression, 10.0:1 should work nicely. If you don't want
to pull the heads, and just want to replace the cams yes, SE 204 cams will do.
Twin Cooled are rated at 10:1
I've always been a fan of the 204, But for the buck i don't think there will be much bang compared to the stock Rushmore cam
Did you dyno the stock cams? If so, can you show us the upgraded performance? I use and like SE-204's, but the Rushmore cams in my '14 RK seem to do ok so far.
