Radio Shack Siren on 2014 FLHTK
#31
#32
http://www.foxbusiness.com/industrie...s-are-closing/ The ones around me are already gone...
Sent from my iPhone using IB AutoGroup
#33
#34
#37
#38
I don't have any pics, but I mounted one with zip ties, in the slot for the stock module, and ran a wire to the other side, and sip tied one to the empty threaded holes under the right cover.
#39
#40
All the stores in my area are now closed but 1 so I just ordered 2 Sirens (273-079) online shipped to my door.
The pin kit suggested was a 9 position male connector part # 276-1427. They mentioned in that post that they were a bit too long to allow the plug to fit back into it's holder. I'm going to trim mine to fit all the way into the connector.
They also drilled a hole through the top of the holder to allow the plug wiring from the siren to slip into the holder so that everything can be sealed up. In that image they drilled from the top and then silicone. I'm going to drill from the bottom and that will hopefully prevent water from seeping into the wiring connector.
Much of the posts I've read about mentioned that 2 together are extremely loud when wired (parallel) together. I'm going to try that.
