2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Problem when Magellan GPS plugged in to cig. charger.
Old 05-21-2014, 07:34 AM
Betteroff's Avatar
Betteroff
Betteroff is offline
Default Problem when Magellan GPS plugged in to cig. charger.
I mounted my Magellan Roadmate GPS on my Ultra. It has been working perfect in my car for over a year. I plugged it in to the cig lighter charger port on the fairing. It works fine for 10 to 20 minutes then the GPS shuts down. I have to press the manual reset on the GPS to get it to come back on. Any ideas?
Old 05-21-2014, 08:24 AM
Pilotmedic's Avatar
Pilotmedic
Pilotmedic is offline
Sounds like a loose connection in the cig lighter. Possibly with the added vibration. I would try and hardwire it in. Then try it you can always put a quick disconnect in
Old 05-21-2014, 08:35 AM
Betteroff's Avatar
Betteroff
I'm going to do that. I am using the Magellan oem charging plug and the plug fuse is not blowing, but somethings up. Thanks for the idea.
Old 05-21-2014, 09:48 AM
tpcowfish's Avatar
tpcowfish
tpcowfish is offline
You have probably already done this, but try it back in your car, if it doesn't do it there, definately issue with power source on bike, just a suggestion to eliminate source
Old 05-21-2014, 09:58 AM
Betteroff's Avatar
Betteroff
I did. It worked fine. Apparently something is wrong with the bike that the GPS is sensitive too. At least it didn't ruin my GPS.
Old 05-21-2014, 10:12 AM
RevRaz's Avatar
RevRaz
RevRaz is offline
Have you tried it without the power source? Running on batteries should last you at least 2 hours I would think. Would at least tell you if its the power source or not.
Old 05-21-2014, 11:03 AM
Betteroff's Avatar
Betteroff
I'll try that on the way home today.
Old 05-22-2014, 07:32 AM
Betteroff's Avatar
Betteroff
Rode home with GPS on battery power only. No problem. A few miles from the house it dies (wasn't fully charged to begin with). I plugged the charger to it and in a couple minutes the gps shut down. So time to direct wire it.
Old 06-09-2014, 07:34 AM
Betteroff's Avatar
Betteroff
Finally did this, this weekend. The GPS is now wired directly to the battery (w/fuse) and no problems at all. Only thing is, now I am wondering whats wrong with the circuit going to the fairing cig. lighter charging port that was causing my problem?
Anyway, I'm leaving Wed. morning for 5 days in the Smokies and all I want to be able to do is roam the mountains all day and then allow the ole GPS to guide me straight back to the motel in the evening.
Old 06-09-2014, 07:44 AM
tlb's Avatar
tlb
tlb is offline
Can you use something like this on yur battery tender plug?
Battery Tender® Motorcycle USB Charger Adapter - iPhone iPad Android Smartphone
Quick Reply: Problem when Magellan GPS plugged in to cig. charger.
