2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Installed the fugly fangs...
Old 10-01-2014 | 02:10 PM
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by Nomadmax
I have the JES fork deflectors on my Road King, indeed they work great. Right now I'm trying to talk him into making some for the Dynas that have a windshield. I have a pair of black JES deflectors (Touring) for use with lowers if anyone is looking, I sold my lowers. PM if interested.
These work on a Dyna:http://www.jpcycles.com/product/561-470#! Had them on my previous bike (`09 Dyna SG ), which had a Harley windshield.
  #142
Old 10-01-2014 | 02:23 PM
Car Doc's Avatar
Car Doc
Originally Posted by scotty918
What size WS are you running? To get the most out of em, they need to be paired with the proper height windshield.
Yup I agree and the adjustable fairing deflectors are a must with the fangs otherwise the air pressure is intensified over the tank.
If I smoked I am pretty sure I could while riding now sure couldn't say that before!
  #143
Old 10-01-2014 | 02:30 PM
HARLEY100TH's Avatar
HARLEY100TH
Scotty, you are right. I think a taller windshield is the key to these things success!
  #144
Old 10-02-2014 | 12:31 AM
Gwaxley's Avatar
Gwaxley
Originally Posted by Kcdcltd
Relative to the 2014 and newer Ultra Limiteds, do you think it is a fitment issue or is a cooling issue (inadequate air-flow to radiators) that has kept HD from coming up with new ones? I know they worked on a Road King I had once upon a time...
Im not sure why Harley is not fitting the 14s, (theres been misprints in the catalogs before) but the JES deflectors are not as wide as the rad inlets. Looking from the front and the bars straight the full rad inlet is exposed. The air vent in the lowers have as much air flow as they did with out the deflectors so I'm not too concerned. But sence you mentioned it and it is still hot in the south, think il monitor the temp awhile. Only had them on the bike a few days, seems to be less air coming from around the tank area, and like the looks.
  #145
Old 10-02-2014 | 09:11 AM
buzdean's Avatar
buzdean
Now have a couple hundred miles one the JES deflectors--they do change the airflow in a good way--winter windshield should be here in a day or two to if there will be a bigger change going from a 8.5" to 12" shield
I can't see them when on the bike so they look great!!
  #146
Old 10-17-2014 | 01:54 PM
Marks57's Avatar
Marks57
Originally Posted by xhere
I have always been annoyed by the buffeting caused by the air rushing from under the tank, main thing was causing my glasses to buzz and had a blur in vision around 75 mph. Thought I would give the fork air deflectors a try although I don't like the looks of them. Installed a pair Friday night as I had a nice ride coming up the next day. I have to say it was night and day difference in turbulence! Rode about 350 miles yesterday, they may be fugly but it would tuff to take them off with the difference they made. Rode a few hours into the night and also have to add the hd reflector led it awesome compared to the stock, lights up both side of the rode and high beam shoots a nice beam down the road.
Do the wind deflectors attached to the fairing on my Ultra Classic do the same thing as "fangs" on the forks of a bike with no fairing or does the fork mounts do a different type of deflection?
Mark
  #147
Old 10-17-2014 | 07:34 PM
GSHOG's Avatar
GSHOG
I had installed the JES deflectors on my '09 Ultra and was one of the first installs on my '14 Limited last year. I think they make a big difference...
  #148
Old 10-17-2014 | 07:38 PM
GSHOG's Avatar
GSHOG
Mark
Two different things. The fairing deflectors merely direct more air up into your face or not, while the fork deflectors redirect the air away from you and greatly reduce the buffeting you would experience without them.
  #149
Old 10-17-2014 | 07:41 PM
xhere's Avatar
xhere
Do the wind deflectors attached to the fairing on my Ultra Classic do the same thing as "fangs" on the forks of a bike with no fairing or does the fork mounts do a different type of deflection? Mark
The fork mount "fangs" air deflectors lessen the air rushing up under the tank... The deflectors mounted on the side of your fairing are not as effective.
  #150
Old 10-17-2014 | 07:58 PM
HD Jake's Avatar
HD Jake
The fangs work fine on the 14's Harley site is wrong, had them on mine, took them off for the summer and getting ready to put them back on soon for the fall and winter... Work great to take the edge off
Quick Reply: Installed the fugly fangs...
