Dyno sheet on CFR, any one?
I'm looking at mufflers for my new King. For this year I just want the slip ons then next year do a complete stage-1.
I like the look and sound of the CFR the best. But I have been told by some good turners that the CFR are hard to get power from. But some others say they don't have any trouble with the CFR.
I can find dyno sheets on just about all other mufflers but I cant find any with CFR. Has any one out there have a dyno sheet you could put up with CFR mufflers? I'm most interested in seeing them on stock motors. Thanks.
You WILL notice a drop in low end with just the CFR's.
I ran my 13 RG with just the mufflers for only about 2 months before going full stage one. Big difference. I'm not a tuner, but I know they're harder to tune than most. I went with a PCV and tune from fuel moto and it ran great...
Going a different route on the '14 SGS, am over the CFR'S. Sorry I can help with the dyno sheet. Its pretty common to buy the CFR's based solely on sound.
Dyno numbers
The 3" baffle will be fine unless you loose the cat then you will be in trouble. To big of a baffle with no back pressure but as long as you keep the cat you should be fine.
