2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Warning - Problem with 21" wheel upgrade on SGS or any ABS 2014
Old 04-23-2014 | 08:54 PM
DD Dont's Avatar
DD Dont
I dont think I have ABS on mine.
Would I need a new fender to go with the bigger wheel? Neck rake? etc..
Old 04-23-2014 | 10:58 PM
Hogpro's Avatar
Hogpro
Former Sponsor
All 14 touring models require brackets to raise the stock front fender for a 21" wheel unlike the earlier touring models (except the CVO's). Brackets range in price from $40 to about $100 depending on the brand.
If you turn on your bike and there is not an ABS light that is orange on before you start moving you do not have ABS. Or you can look at the left side (from on the bike) of the front wheel and see if there is a regular axle spacer or a black ABS pick up with a black wire coming off of it which is usually zip tied to the brake line.
Old 04-24-2014 | 12:02 PM
JC0311's Avatar
JC0311
Hogpro-would changing the rear to a 18x5 with a 180 tire raise the back any and what about the 200 rear would that change the handling if the bike any. I'm not too worried about the 21 raising the front any as I have the HD lowering kit for the front forks. I got the front lowered and got the MCC seat mod and I'm really happy with the way it rides and especially the fact that I'm flat footed.
Old 04-24-2014 | 12:13 PM
Hogpro's Avatar
Hogpro
Former Sponsor
The 18x5.5 raises the back about 1/2". I won't mount a 200 tire on an 18" rear wheel for your bike as they have been known to cause a high speed wobble thus the 180/55/18 is the way to go on that.
The other sizes for the rear would be 16x5.5" (1/2" wider than the stock rear wheel but the same diameter) with a 180/65/16 tire which is the same size as the stock tire or a 17x6.25 (1" larger in diameter and 1.25" wider than stock) with a 200/55/17 tire. The 17 will sit maybe 1/4" higher than stock.
How else can I help?
Old 04-24-2014 | 12:35 PM
JC0311's Avatar
JC0311
But would running an aftermarket 16 in the rear still present the ABS light issue, would that be correct?
Old 04-24-2014 | 01:02 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Correct. On 2014 ABS touring models with linked brakes you cannot do a 21 front wheel with a 16 rear wheel. It would need to be either a 17 rear with a 200/55/127 tire or an 18x5.5 with a 180/55/18. So if you want to do just the front 21" on a 14 with ABS you are out of luck.
If you have a 2014 model WITHOUT ABS you can do any size combination without ill effect.
Old 04-25-2014 | 04:55 PM
WanaRyd Wheels's Avatar
WanaRyd Wheels
Sponsor
Just an update guys... We just heard from a customer that his shop got a Dunlop 130/60/21 tire to work along with the stock 16" rear wheel due to the lower 60 profile tire. We are doing some testing here and will keep this thread up-to-date with what we continue to learn on this matter.
__________________
WanaRyd Motorcycle
1-888-926-2793
Old 04-25-2014 | 04:56 PM
WanaRyd Wheels
Sponsor
...just a note as well.. the rear tire they used with the 130/60/21 front was the 180/65/16 Dunlop.
Old 04-25-2014 | 05:09 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Good info, we'll be standing by waiting for any more info on the subject. Thanks.
Old 05-07-2014 | 08:18 PM
alika808's Avatar
alika808
Is there any updates on this? Im looking to run a 23 up front
Quick Reply: Warning - Problem with 21" wheel upgrade on SGS or any ABS 2014
