2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
XM Module Antenna
Old 04-10-2014, 07:00 AM
Diggman's Avatar
Diggman
Diggman is offline
There are quite a few responses to this thread in Touring.
I am the one that posted pictures of my relocated XM antenna on the dash. Since then, I have moved it just a smidge farther away from the windshield because I added the Harley 3 pocket pouch thingy.
Reception is very good. I still experience drop outs when there are big trees or buildings that block line of sight to the south, but this mod helps - even if only a little bit.
Diggs
edit: Thanks, Ghostrider1967. You beat me to it.
Old 04-10-2014, 07:09 AM
WildThang's Avatar
WildThang
WildThang is offline
Originally Posted by Ghostrider1967
Someone on this or the touring forum mounted the antenna on the inside window dash opposite the vent fairing button? It didn't look too bad and he claimed he got better reception? I'll post it if I can find it?
Great idea...just moved mine and going to test out...
Old 04-10-2014, 07:44 AM
WildThang's Avatar
WildThang
Bingo....spots where I normally dropped out among trees in my local area is able to see the sat now...
Thanks everyone
Old 04-10-2014, 08:57 AM
NiteOwlNY's Avatar
NiteOwlNY
NiteOwlNY is offline
I know all the roads and overpasses that drop out in my truck, I'm going to assume this will be no better or worse. I was wondering how/where the antenna went and thanks for the responses.
I wish they'd move some of their web only channels onto the regular radios... Being a big Country and Classic Rock fan if the Harley XM radio could get "Red, White and Booze" I'd have the module on order already... I stream it from my phone, but it isn't the optimal way of listening to music.
Old 04-10-2014, 06:51 PM
gcroach's Avatar
gcroach
gcroach is offline
Question for those of you that have installed the XM module on the 2014 Limited. I installed the module this evening but have not activated the 3 month trial period yet as not quite ridding season here on the east coast of Canada yet. I was expecting to get the preview channel and some audio, however didn't get any audio. Has that been your experience? I know when you get a cage with a radio not subscribed you get audio on the preview channel, that's why I was expecting something. Now I am wondering if module is working although it does display the radio id.
Thanks in advance.
Old 04-10-2014, 07:31 PM
LeeH's Avatar
LeeH
LeeH is offline
I didn't have audio either. And, it sook a loooong time to activate when I did register it. Be patient!
Old 04-11-2014, 06:35 AM
Ghostrider1967's Avatar
Ghostrider1967
Ghostrider1967 is offline
Thanks in advance.
When I installed my xm module it took awhile to receive the data, but I did get the preview channel while I was waiting. Had a problem getting the radio id # too. I believe the new software updates to the infotainment gets it now. After two hours of receiving data, mine still didn't work. I pulled the 50a fuse, waited 5 minutes. The id was there and called SiriusXm and got the 3 months free. Little hint, if you wait long enough to sign up for the subscription, you should get a better deal? The will call you the week before for a deal. I'm probably moving my antenna to the dash. Most gps antennas need a clear view to the sky.
Old 04-11-2014, 08:28 AM
scottt's Avatar
scottt
scottt is offline
Someone needs to come out with a xm antenna located in the center bar on the 14 fairing vent. That would be ideal.
Cheesehead_13
Audio Systems
12-16-2017 11:25 AM
cycle7447
26
04-03-2017 10:21 AM
howitzer88
Audio Systems
03-02-2016 06:44 PM
KY HDRider
05-31-2012 06:56 PM
Casper
05-11-2008 04:21 PM
Quick Reply: XM Module Antenna
