Visor Trim Ring
Visor Trim Ring
OK, maybe I'm an idiot here but here it goes. I bought the Visor Style Trim Ring p/n 67700216 and the included instructions say it mounts over top of the OEM trim ring. I tried installing this thing last night and I'll be damned if I could get it to fit correctly.
Anyone, install one of these before and if so, is there anything special that needs to be done that is not clearly explained in the instructions??
Any help would be appreciated.
Thank you,
DW
Thank you,
DW
I just put one on my Limited. Read the instructions CAREFULLY. Make sure you loosen the stock ring enough to get the lip of the accessory ring behind the stock ring. The accessory ring only has a lip on the bottom half. Tap it on with the heal of your hand to make sure it seats. Then tighten the STOCK ring screw, after that is snug, once again making sure the accessory ring is seated, tighten the accessory ring screw. I put some blue loctite on that special nut as well. Mine fits great.
Yes it is normal, same thing here on my RK. Have seen pictures of other bikes with the trim ring and they all have that gap. Poor design.
Might try the strap idea that Bushpilot mentioned, that gap drives me crazy.
