When to change over to Synthetic on a New SGS
I realize the subject of synthetic has been discussed at nauseam but I think this question is a little more specific. I did a search but didn't find this specific answer or just missed it in all of the synthetic threads out there.
I will be taking my new SGS in for the 1000 mi service probably in mid summer and was wondering if it would be OK to have them switch over to syn at this time. Wasn't sure if it was too early in the life of the engine or am I smoking dope.
Look forward to hearing back from you.
By the sources that know engines (especially the new tight tolerance engines), the oil that is considered breakin oil should remain until the first service at 1000 miles. Then you can run Synthetic Oil from that point on. For cars & trucks, it is after the first 500 miles, but on Harley's it is recommended to wait until you have reached 1000 miles.
I am not a dealer, nor expert in oils, but I do work for and Oil and Gas company. I also worked for companies that produced the base stock for Synthetic Oil called Group IV PAO's (PolyalphaOlefins).
SYN3 is not 100% Synthetic Oil and do not let MOCO tell you otherwise.
According to the "Material Safety Data Sheet" for H-D's SYN3, it is chemically a blend of 60% synthetic and 40% petroleum oils.
Manufactured by - Citgo Petroleum.
It is not illegal but it's certainly deceptive. The Courts have ruled that it is legal to advertise a product that has a chemical composition that includes at least SOME synthetic properties as a "synthetic lubricant".. in the case of SYN3, that oil is a 60/40 blend and not a true, 100% synthetic or anything even close to it.
Pure synthetics are PAO based only such as Mobil 1, Redline, Amsoil. Because the motorcycle industry for oils do not rate them like for automobiles, they do not have to disclose the blends in oils. This is where SYN3 gets around this.
I am not advocating anything here other than to pick and chose your oil based on your own research and recommendations. Harley wants you to buy their over priced oil and claim that without it, your engine will fail and warranty will not be honored. BS! All is needed is a good quality oil, change intervals done properly and if failure of a part(s) occurs during warranty that the MOCO must honor it.
The reason a CVO can claim they use SYN3 from the start is that it is a SYN/BLEND. No engine manufacturer both automotive nor motorcycle recommends breaking in a engine on Pure Synthetic Oil.
But it is your choice!
