2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
When to change over to Synthetic on a New SGS
Old 03-26-2014, 04:39 PM
Gunnysgt's Avatar
Gunnysgt
Gunnysgt is offline
That was good info on the Syn3 being a blend. For a while, Harley was selling oil marked as a blend of dino and syn. I think I may still have a bottle of the blend stuff in the garage. When they started pushing Syn3, they stopped selling the blend stuff since I have not seen it on the shelf for a while. I've tried all syn, and different combos of that. Now I run the Harley primary lube in there and full synthetic in the engine and syn gear lube in the tranny.
Old 03-26-2014, 10:21 PM
dhermann43's Avatar
dhermann43
dhermann43 is offline
Originally Posted by texaspirate
I am not a dealer, nor expert in oils, but I do work for and Oil and Gas company. I also worked for companies that produced the base stock for Synthetic Oil called Group IV PAO's (PolyalphaOlefins).
SYN3 is not 100% Synthetic Oil and do not let MOCO tell you otherwise.
According to the "Material Safety Data Sheet" for H-D's SYN3, it is chemically a blend of 60% synthetic and 40% petroleum oils.
Manufactured by - Citgo Petroleum.
It is not illegal but it's certainly deceptive. The Courts have ruled that it is legal to advertise a product that has a chemical composition that includes at least SOME synthetic properties as a "synthetic lubricant".. in the case of SYN3, that oil is a 60/40 blend and not a true, 100% synthetic or anything even close to it.
Pure synthetics are PAO based only such as Mobil 1, Redline, Amsoil. Because the motorcycle industry for oils do not rate them like for automobiles, they do not have to disclose the blends in oils. This is where SYN3 gets around this.
I am not advocating anything here other than to pick and chose your oil based on your own research and recommendations. Harley wants you to buy their over priced oil and claim that without it, your engine will fail and warranty will not be honored. BS! All is needed is a good quality oil, change intervals done properly and if failure of a part(s) occurs during warranty that the MOCO must honor it.
The reason a CVO can claim they use SYN3 from the start is that it is a SYN/BLEND. No engine manufacturer both automotive nor motorcycle recommends breaking in a engine on Pure Synthetic Oil.
But it is your choice!
Great Post and great information, My thoughts are to run reg 20/50 Harley oil for the first 3-5 oil changes then switch to a full synthetic.
Old 03-28-2014, 06:31 AM
mwegryn's Avatar
mwegryn
mwegryn is offline
Getting Amsoil put in mine as we speak. The tech recommended against the Syn-3 even though I was planning on using the Amsoil anyhow. Makes me wonder what he knows or has seen.
Old 03-28-2014, 06:49 AM
pjim's Avatar
pjim
pjim is offline
At one time Mobil 1 stated on the container it was 100% synthetic minus the base carriers. Many years ago.
Is Mobil 1, 100% pure synthetic now?
Old 03-28-2014, 06:50 AM
little5150's Avatar
little5150
little5150 is offline
I thought a full Synthetic Oil was way to slick for brake in. The parts don't wear together or with each other when braking in with a full Synthetic. In other work it lubes to well. I thought a motor was not fully broke in tell about 2500 miles. That what S&S motor recommends. I always waiting until 2500 mile before I started adding full Synthetic. I think brake in is the most important thing to making a motor last. But what do I know.
Old 03-28-2014, 10:04 AM
texaspirate's Avatar
texaspirate
texaspirate is offline
dhermann43, I only want to inform and not make it gospel for anyone. All need to make their own choices in this area.
I too, run with HD SYN3 for the first oil change at 1000 miles. After that, I use what I feel is the best Synthetic Oil for my application. I am not going to sway anyone which is best since we all have our own favorites.
To answer little5150 question. I am pretty well familiar with Mobil 1. I will say this, I do exclusively use this oil in my cars! Always have since 1982) and is standard OEM oil for my 2010 Camaro SS. It is 100% PAO based synthetic oil with additives.
Mobil 1 makes the automotive brand and the motorcycle 4 cycle brand. Different additives are what separate the two products, but the base stock is still the same.
I have not yet used Mobil 1 Motorcycle oil yet on any of my motorcycles. I have wanted to go with Mobil 1 MC on my Ultra the next oil change.
Old 03-28-2014, 10:17 AM
little5150's Avatar
little5150
I have been using Mobil 1 in all my vehicle's for years, even my Harleys, 15 plus years. I have not had any problems with it. Some one told me that Harley oil is Mobil 1 with the Harley name, I don't no if it true or a bunch of bull sh*t. I have a hard time be leaving it.
Old 03-28-2014, 10:26 AM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
Although I dont use the stuff I was told Amsoil is the only class V base stock syn while all others are class IV.
Old 03-28-2014, 11:12 AM
texaspirate
soft 02, this is another marketing tool for people and to allow others to claim some sort of superiority over another.
Here is a fact between the two Groups.
Group IV base oils are polyalphaolefins (PAOs). These synthetic base oils are made through a process called synthesizing. They have a much broader temperature range and are great for use in extreme cold conditions and high heat applications.
Group V base oils are classified as all other base oils, including silicone, phosphate ester, polyalkylene glycol (PAG), polyolester, biolubes, etc. These base oils are at times mixed with other base stocks to enhance the oil’s properties. An example would be a PAO-based compressor oil that is mixed with a polyolester. Esters are common Group V base oils used in different lubricant formulations to improve the properties of the existing base oil. Ester oils can take more abuse at higher temperatures and will provide superior detergency compared to a PAO synthetic base oil, which in turn increases the hours of use.
Old 03-28-2014, 11:15 AM
soft 02's Avatar
soft 02
soft 02 is offline
Thanks Tex. I tried Amsoil once and it made my motor more noisy. 126,000 with M1. So far, so good.
Quick Reply: When to change over to Synthetic on a New SGS
