Air wing detachable luggage rack light kit
Anyone put an Air wing detachable luggage rack light kit on a 14 streetglide?
Looking for the connector that the light harness plugs into. Instructions say under the seat but none there, that would mate. Also looked under side panel.
It's hidden or I'm blind....
Thats what I used to put the air wing rack light kit on,The air wing rack looks better than the standard rack they put on the Limited. (no offense guys).IMO
On your 14 SGS, it will be at the back side on top behind the battery location (rear fender). Install the harness for the y connector. The rack light make sure the wiring is long enough (you have not cut it short) to reach that connector under seat. What they don't tell you, to run the light kit for the rack, you always must remove seat to install and remove that rack. I have one and am going to eventually modify (extend the harness connection so that it can be connected without removing the seat.
Evidently they have relocated the connector to a different location on my bike. It is a 14 Street Glide, I'm still looking for the connector. Picture shown on directions show connector on back, top of battery area. Nothing there. Unless its between the battery and rear fender, I'm at a loss. Surely you don't have to remove the rear wheel or pull the battery box to get to this??
