Pulled main fuse now no power
So, this weekend I installed the detachable tour pak kit on my limited.
Pretty easy install but this morning when I put the main fuse back in to check lighting I got a small arc and no power to bike, fuse looks good and no pinched wires that I can see. WTF did I do?
Well I was able to take another look at it this morning and check connections and wiring, everything looks good, nice and neatly tucked away.
So, I put fuse back in and turned ignition back on and everything is working fine. Yesterday when I went to turn ignition on it was in steering lock position,
I don't want to tell you what I think happened, but I will. I believe I turned the ignition from lock position only to the off position, yep! Only thing wrong with this theory is with ignition in off position the security light was not flashing, wondering if the system needs time to boot up.
Cabin fever!!
Cabin fever!!
blueangel73
09-20-2017 03:50 PM
Robtarra39
09-07-2012 07:47 AM
