2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
View Poll Results: Who's had twin cooling leaks
Had at least one leaking episode, not convinced it's fixed
14.67%
Had at least one leaking episode, I believe it is fixed
16.00%
Never leaked
69.33%
Voters: 75. You may not vote on this poll
Twin cooling issues poll
Old 02-29-2016 | 08:02 AM
Harttoo's Avatar
Harttoo
Bought mine November 2013,never leaked in 30,000 miles.No problems at all.Recalls,yes,but no problems with anything.
  #42
Old 02-29-2016 | 02:05 PM
Brewmany's Avatar
Brewmany
No issues with the cooling system on my Limited yet, either. Except for dropping a saddlebag, no problems with the bike at all. HD made good for a new saddlebag.
A couple other recalls for things that didn't surface as problems.
  #43
Old 03-12-2016 | 08:27 PM
Stacy73's Avatar
Stacy73
Bought my bike in Sept of 2013. After the first thermostat went they received the replacement which was also bad. Then the radiator cap was bad and I forgot the other bad part. I checked the new part and it looks diffrent from the last one. I think they finally got it.
  #44
Old 04-21-2016 | 07:24 AM
Stacy73's Avatar
Stacy73
Last fix lasted about 100 miles the dumped antifreeze again. Dealer still trying to find out why. This is getting old.
  #45
Old 04-21-2016 | 07:51 AM
bmaier's Avatar
bmaier
9800 troublefree miles, the fans came on yesterday for a little while
  #46
Old 04-27-2016 | 11:45 PM
offthewall's Avatar
offthewall
About 7,000 miles on my 2014 Limited now. Never a leak. Have gone through all the recalls.
  #47
Old 07-10-2016 | 09:12 AM
Stacy73's Avatar
Stacy73
They finally figured out what was wrong. My coolant pump was sticking. It ran ok most of the time, however every now and then it would stick locking the hot coolant in the hose. This caused the thermostat to overhear and the joint would let go. They replaced the pump in April and 5000 miles later it is working fine. The pump works when it should and everything is ok. I've ridden in a lot of 90+ degree weather, several parades and all is well.
  #48
Old 07-10-2016 | 12:10 PM
smitty901's Avatar
smitty901
12,000 miles on the RGU no issues
  #49
Old 07-10-2016 | 06:20 PM
almostakeeper's Avatar
almostakeeper
13,000 miles in 23 months on mine. Only problem so far is the left side switch pack replaced last week, and I'm down to 2 weeks of warranty left.
  #50
Old 07-10-2016 | 06:31 PM
ACLazer's Avatar
ACLazer
Well, 16,500 miles, in two years on my 14 Limited. Never had a Coolant issue at all.
When it's hot out, after a ride, I do on occasion manually turn the fans on, when I get it home in the garage and let them run a bit.
Quick Reply: Twin cooling issues poll
