2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
What are you using the auxillary power plug for?
Old 02-25-2014, 09:02 AM
GlidingJoe's Avatar
GlidingJoe
GlidingJoe is offline
Originally Posted by Spowell928
I was talking about the one on the right lower side of the front fairing. Looks like a cigarette lighter plug.
I completely forgot about that one. I don't use it...
Old 02-25-2014, 11:06 AM
OldPhat's Avatar
OldPhat
OldPhat is offline
USB port for the IPod. Lighter plug to charge a smart phone, or run a small air
compressor if needed.
Old 02-25-2014, 12:23 PM
jkane13's Avatar
jkane13
jkane13 is offline
I plan to use the tour pack one for charging my tablet while we are on the road. It can charge other things I guess.
I want to plug my phone into the usb in the phone/mp3 box on the front. But, it doesn't seem to be long enough to fit a phone and the usb cable while still closing the door. Have to try again and see if I can force it.
The pig tail under the side cover is for a trickle charger to the battery. I use it with my battery tender. I have adapters to make it into a cigarrette plug also. Don't use them though. Did on my wife's trike but then wired one seperate for her to use.
I didn't know there was a plug under the fairing. Have to look for it!
Old 02-25-2014, 12:31 PM
Rustrtal's Avatar
Rustrtal
Rustrtal is offline
I use mine to hold a soft rubber plug.
Old 02-25-2014, 04:21 PM
Crusader45's Avatar
Crusader45
Crusader45 is offline
I use mine to keep pushing the plug in that is always falling out. You'd think they would have made that a little tighter fit.
Old 02-25-2014, 04:38 PM
d7dun1010's Avatar
d7dun1010
d7dun1010 is offline
Hello,
I use the plug inside the tourpak to power and recharge my cellphone.
I found that if I turn the Bluetooth on, I can make and receive calls through the bike and get it recharged at the same time.
BTW: You can also have your phone anywhere on you or on the bike and as long as the Bluetooth is on, you can get and make calls. The phone DOES NOT have to be connected to the bike by cord.
Hope that helps?
D
Old 02-25-2014, 10:46 PM
ScottCocoaBeach's Avatar
ScottCocoaBeach
ScottCocoaBeach is offline
Tour pack connector Cig to USB power for charging phones and such as others have mentioned.
For the fairing one I plug in my radar detector and use this mount:
Amazon.com: RAM Handlebar Rail Mount with Zinc Coated U-Bolt Base and Universal X-Grip(TM) Cell Phone Holder: Car Electronics Amazon.com: RAM Handlebar Rail Mount with Zinc Coated U-Bolt Base and Universal X-Grip(TM) Cell Phone Holder: Car Electronics
I just need to look into a way to hear the audio alerts better.
Old 02-26-2014, 10:21 AM
eqcons's Avatar
eqcons
eqcons is offline
Old 02-27-2014, 08:05 PM
ScottCocoaBeach
Old 02-27-2014, 11:27 PM
chopper chuck's Avatar
chopper chuck
chopper chuck is offline
Default Fairing plug
Has anyone used the fairing plug for a heated jacket ? would like to know if there have been any problems like that it will shut off from to much current draw or ???? Does it work just Great ( I hope)..
Quick Reply: What are you using the auxillary power plug for?
