4.3 Boom 1.17.1.4 'Bugs'
I am not sure of how much overlap there is between the 4.3 and 6.5 systems outside the differences discussed elsewhere in this forum. So I've titled this: "4.3…" Much might apply to the 6.5 system as well…
When streaming music from my iPod connected to the 4.3 system via the USB connector, every few minutes (10 or 15) there's a long 'pause' in the music (2 or 3 seconds) when the music stops, before it resumes again. This was the case with the 1.17.1.2 firmware, and is still the case with the 1.17.1.4 firmware. I have a third generation iPod.
Every once in a while, after I turn the ignition on, there's a long space (sometimes several minutes) when the system screen is blank (the radio might be playing, or might not during this time). Eventually, the normal window appears (the Accept warning). This is unpredictable, but appears to be most likely when I come out from work in the afternoons. This was true of both version of firmware cited…though it might have been a little more frequent with the older version.
As discussed in another thread, the radio changes state when the ignition is turned off, i.e., goes to 'off' when it was 'on', or vice versa for the next time the ignition is switched on. I *believe* this is better in the 1.17.1.4 update. It sure doesn't happen as often. Though I think the radio has turned itself 'off' once or twice in maybe 50-100 ignition cycles. (I don't think it's turned itself 'on' during power-up when it was 'off' during shutdown, since the update).
Anyone see these problems with their 4.3 (or 6.5 system)? Do you see other flakiness with the 1.17.1.4 firmware?
Alan
Alan
I gotta tell you, so far mine has operated almost flawlessly. I may have an occasional pause in the music, not really sure. Seems like it has happened but it may have been while streaming Pandora. Can't remember. The only thing that I would complain about is the boot-up time required to get to the silly "Accept" screen. Seems like that takes too long.
jt
jt
Alan
Alan
Well, I got a chance to ride a little over 200 miles today and I found that the CB no longer mutes on mine either when I hit the PTT. It worked fine before I installed the update. And I don't hear myself through the headphones like I used to either. Someone else mentioned turning the intercom on with VOX as a workaround. That seems to work for now.
Since the update, it does seem to me that the AVC seems to work better now. Not as well as previous bikes, but better than before. Also, it seems like the unit boots up quicker than before. It seems like it doesn't take nearly as long to get to the accept screen when starting the bike. Pretty typical for software. Fix several things and screw up a some others functions in the process. No different than with cars.
jt
jt
Harleyjth - I just got my bike back from the dealership - did the bottle neck recall and also upgraded the radio software.
I don't understand what you are referring to when you said the CB no longer mutes when you press the PTT switch. If the CB is on..and you press the PTT switch - then aren't you transmitting? Why would this mute the CB?
I'm guessing two things. First it takes the liability off the MOCO. Second it might have something to do with the Nav. Every time I turn my Garmin on I have an "agree" screen. And before anybody says it, yes I know this is not a Garmin based system.
jt
