2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
'14 Street Glide ABS light with linked brakes issue
Old 02-04-2014 | 05:03 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Default '14 Street Glide ABS light with linked brakes issue
Has anyone had an issue with the ABS light on a 14 model with linked braking? I have a customer who is having an issue with the ABS light coming on on his '14. The wheel is a Performance Machine wheel. Has anyone else had this issue? This is the first issue i can remember to date.
I advised to clean off teh surface of teh ABS pickup and bearing, ensure that the pickup is making contact with the bearing, try resetting the ECM by disconnecting and reconnecting the battery. bByond that I am at a loss. Suggestions would be great.
The bike is not here at our shop but in another state so getting the bike here in to our shop is not possible. Thanks in advance for any help you may provide.
Old 02-04-2014 | 06:08 PM
thirstybob's Avatar
thirstybob
Not to insult anyones intelligence but the light comes on at start up and blinks until you get up to about 10 mph then shuts off.
Old 02-04-2014 | 06:12 PM
DeeRoe's Avatar
DeeRoe
Veteran: Air ForceVeteran: Marine Corp
What he said....
Old 02-04-2014 | 06:25 PM
Gunnysgt's Avatar
Gunnysgt
Yea, you didn't mention WHEN the light is coming on. If it's while riding, that's one issue but as the others said, if it's at start up, that's normal
Old 02-04-2014 | 06:29 PM
Kesean's Avatar
Kesean
I'm having the same issue. I have PM wheels on mine and it will initially go out then it will come back on and stay on. I'm at a loss myself.
Old 02-04-2014 | 09:11 PM
Hogpro's Avatar
Hogpro
Former Sponsor
The light is going off and then coming back on above 50 mph.
Old 02-04-2014 | 10:38 PM
cfreeze's Avatar
cfreeze
Is there a current or historic code? It will probably be a wss short/open. had an after market wheel that keep doing this, found the ABS bearing was too far in the bore of the wheel. removed the bearing put in a thin(very thin) spacer behind the bearing. problem never cam back.
Old 02-04-2014 | 10:39 PM
btsom's Avatar
btsom
Purely supposition which hopefully will be confirmed or dis-proven once there is more familiarity with the 14s and linked brakes.
Both of the machines have after market wheels. By fiddling with aspect ratio the circumference of the tire can remain the same as the factory wheel/tire combination or be considerably different. I am wondering if there is a built in self diagnostic watching the difference between front and rear wheel rpm. When difference exceeds a certain number, it trips the light. The rpm difference sensed with the new wheels would suggest a sensor or wiring problem if it happened with factory tires and wheels. Hopefully there would be accessible spots in the computer to update for changes in tire size to eliminate the false light.
Old 02-05-2014 | 04:08 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I guess it could be the linked braking as that is really the only difference with the 14 models than previous years with ABS. Can anyone else shed any light on this?
Old 02-05-2014 | 04:54 PM
03snake's Avatar
03snake
I'm thinking that with linked brakes the ABS computer is comparing not just individual wheel slip but also comparing rotation rates of front to rear wheels. If that's the case (and I'm just guessing) if you change the overall diameter of either front or rear wheel/tire the ABS computer is not going to like it. As they are linked electronically it will sense a rotation rate from the modified wheel/tire outside it's programed stock wheel/tire configuration and possibly kick the light on.
Quick Reply: '14 Street Glide ABS light with linked brakes issue
