Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics
#341
I feel like I am missing something. I have CD led turn signals front and rear and the rsg magic box for the rear strobe effect so I was thinking that the 8" plasma rods in the turn brake mode would be another great addition. It looks like they would adhere easily to the fender fillers between the bags and fender without any bracket, composite filler or anything. I have seen some videos just attaching them there and they look very stealth. Is the bracket issue only a '14 issue?
#342
#344
#345
2014streetglide (04-24-2016)
#346
#347
The MPR-BCM makes installation a lot easier, not only does it make an easier install, but you do not need to splice into your stock wires when using the supplied posi taps. For the price of the MPR-BCM its well worth it.
#348
They do. I had my plasma rods on my 13 and stayed firm for almost 3 years. Transferred them to my 16 rgs just fine. Clean your mounting with rubbing alcohol and use new 3m and your fine. No need for extra expenses on mounting brackets.
#349
Thanks for the info, but will I still be able to just use the plasma rods as brake and turning lights only with it?
#350
