2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics
Old 08-19-2014, 10:02 AM
rcmty's Avatar
rcmty
rcmty is offline
Default Custom Dynamic LED lights
I just instal my LED lights from custom dynamic which was the 8" plasma rods, LED rear lights and the Tri-bar rear fender light. Everything was straight forward easy instal with easy to follow instructions. I really wanted the brake light flasher which would strobe flash all my rear lights and dim the LED running lights down, but they have no brake light flasher for the 2014 street glide yet. Well what I ended up doing was removing my LED brake/turn/running/ light and putting the factory bulb back in. The reason was the LED light was so bright that it look like my brake light was stuck on and most drivers behind me was thinking I was riding my brakes, yes they are that bright with just running lights and I'll keep them until custom dynamic comes out with a way to dim them down to match the other lights on the rear of my bike. I can say all my lights from custom dynamic is well worth there money.
  #272
Old 09-14-2014, 04:24 PM
offthewall's Avatar
offthewall
offthewall is offline
Lightbulb Added Radiantz Custom Flexible LED Array
Since running the Plasma Rods as my only turn signals when I have the Tour-Pak off, I was concerned with visibility of the near side blinkers being blocked by the saddle bag.
I put a Radiantz Custom Flexible LED Array under the fender tip light.
The array is split in two, one side left blinker, the other right blinker. Both light up with the brake like the Plasma rods. I wired these straight into the stock turn signal plugs in the rear taillight using H-D metal pins and the plastic plugs.
I'm really happy with the visibly of the brakes and turns at any angle from the rear now.
Some picts:
OFF close up; OFF far; RIGHT TURN; BRAKE.
Attached Thumbnails Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics-img_0767.jpg   Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics-img_0757.jpg   Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics-img_0756.jpg   Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics-img_0719.jpg
  #273
Old 10-09-2014, 04:36 AM
Mray81's Avatar
Mray81
Mray81 is offline
I'd love a set of brackets next time you make some more.
  #274
Old 10-09-2014, 03:18 PM
roadkinglobo's Avatar
roadkinglobo
roadkinglobo is offline
Slick setup OTWall. Looks really sharp. probably looks amazing at night.
  #275
Old 10-09-2014, 03:59 PM
offthewall's Avatar
offthewall
Thx.
It really does get your attention at night when they all come on!
  #276
Old 10-24-2014, 11:44 AM
scarin's Avatar
scarin
scarin is offline
Finally got my rods installed and it was a simple process especially with the MPR-BCM. Wiring was a snap. Just remember some earlier posts that state tapping into the orange wire are inaccurate unless you want the rods to work when you are in accessory mode. Both Oranges (if you have the TFC3's) should go to the blue wire.
14FLHX your brackets are great, fit perfectly and made the install easy. Thanks again for taking the time to engineer and sell them to the rest of us. Biggest pain was removing the antenna bracket which was really no big deal. I didn't try drilling through as I don't really use FM and I have a hidden antenna.
Love the look and the extra visibility of the rods.
  #277
Old 10-25-2014, 08:02 AM
junglejoe's Avatar
junglejoe
junglejoe is offline
I have this setup on my dyna, but I had to buy the converter for the led's, do you have to buy that for the 14's? Or do you take the bulbs out and replace with the led bulb? I also bought the box where you can have either or all tail lights flashing or no flash when you apply the brakes.
What exactly is that bracket for??
  #278
Old 10-25-2014, 11:45 AM
14 FLHX's Avatar
14 FLHX
14 FLHX is offline
Joe, go to the 1st page and look over the post and it will all make sense.
  #279
Old 10-25-2014, 11:46 AM
14 FLHX's Avatar
14 FLHX
14 FLHX is offline
scarin, Im glad they worked out good for you. Thanks for the feedback.
I will be making more brackets in a few weeks.
  #280
Old 10-25-2014, 07:38 PM
DABB's Avatar
DABB
DABB is offline
May I get a set of brackets?
Quick Reply: Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics
