Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics
#261
A pair of Plasma Rods (8") GEN-MPLASMA-RED-PR
http://www.customdynamics.com/plasma_rod_led_lights.htm
You need to decide if you want just brake and Turn or Run included.
If you want to use the rods as Run, Brake & Turn, you will need 2 TFC3
http://www.customdynamics.com/plasma...Dual_Converter
and to make the install painless get this connector.
MPR-BCM 3rd item from the bottom.
http://www.customdynamics.com/loadequalizer.htm
Then Install and post PICTURES...
#262
Getting ready to finally install my PRs and have all my parts, including the 2 TFC3's and the MPR-BCM but a little confused on the wiring info here.
Montycop said
This is how I have mine wired to the BCM-MPR with the TFC3's:
With MPR-BCM
Right rod- Red to purple, Orange to orange, black to black
Left rod- Red to brown, Orange to blue, black to black
The only wire on the MPR-BCM that doesn't get used for run/brake/turn is the red wire.
However the directions for the MPR-BCM label the wires as follows:
Black - ground
Blue - running
Red - brake
Brown - right turn/ brake
Purple - left turn/brake
Orange - auxiliary power
So I think the left and right are switched and also wondering if the two orange wires should both go to the blue running wire or as mentioned above.
Thanks hoping to install in the next few days.
With MPR-BCM
Black - ground
Blue - running
Red - brake
#267
#268
Send me a pm with your contact info and I'm sure we can work together to get pre 14 brackets fabbed up.
#269
Last year I went to DelMarVa Bike Week and Custom Dynamics was there. After seeing their display of all kinds of lighting systems I ended up buying flashing brake lights, LED turn singles front and rear. The integrated front running lights with front turn signal. Which I think are very sharp. I ended up spending over $200. The best part is they did all the installation for me free of charge at the bike week. It took about one hour to do, so while they were installing all my lights exactly the way I wanted them, my wife and I walk over the large stage area, listen to the band, and had a couple of cold ones. It turned out to be a great day.
My advice is to get to their location early in the morning. They do draw a crowd and if you want them to do the installation you will want to get in line first. Custom dynamics has been a first-class company with me I think you will be very pleased.
