Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics
#232
Also to the poster that said they called, the MPR-BCM does work with the SGS. Sounds like CD has some people just as confused by the new bikes as some of us are.
#233
Edit;
Whoops, sorry MontyCop05, I just saw your post on the next page after I did mine.
#236
You really don't NEED the MPR-BMC ever. It just makes the install easier, cleaner and reversible. If you ever want to take it out, just unplug with no trace or damage to the wiring harness.
#237
Ahh...ok. No worries. The clarification for those that didn't pick up on that probably isn't a bad thing. The pre 14' bike actually do need a R/B/T module (electronic magic box for those that care) to get this function. The TFC3 is really just a glorified splitter for the power wire.
#238
#240
Having trouble with a simple custom installation of Plasma Rods. Using EPZ2 module and plasma rods to run as Brake/Turn.
Individually, brake works, turns work. It was my understanding that turn would take priority over brake using the EPZ2 which would cause the turn side going from solid to off while opposite side stays lit as long as brake is applied. The opposite happens, when turn signal is activated and brake applied all stay lit. When brake is released resumes turn. Any wiring insight?
Current hookup-
EPZ2 output red and black to Plasma red and black
EPZ2 input red to brake/Orange to turn (purple left/brown right)/black to ground.
Thanks!
Current hookup-
Thanks!
