Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics
#181
I trying to find out from you guys (pswomack, monty,etc) that have the plasma rods set up for run/brake/turn some info about the appearance in the three modes.
Run - Is this mode the rods on dimly?
Brake - The rods at full brightness?
Turn - Do the rods flash "dim to bright" or "off to bright"?
Thanks.
Thanks.
Run - rods on dimly
Brake - full brightness
Turn - dim to bright
Run
Brake
I dont have a pic of it in blinking mode, but its dim to bright.
#182
Thanks, I already have the Plasma Rods hooked up using the MPR-BCM for brake/turn. I think I'd like to go full Run/brake/turn.
#183
#184
Several guys I ride with liked them so much, they have ordered them also. Can never have to much light on the rear!
#185
#186
That "unsells" the run/turn/brake for me. I prefer the "off to bright" for the turns. I think it's more attention getting. I'd rather trade that for the running lights.
#187
Ok, I was just about to ask why 14FLHXS's were turn/"dim to bright" and yours and Monty's were turn/"off to bright".
offthewall / 14FLHX
Check out the below link. If you scroll down about half way and there is a video of a 2010 Roadglide that shows the turns as "off to bright". I realize this just a video so we don't know for sure if that's how it really is.
I'm wondering if hooking up to the rear module at the fender tip makes a difference vs under the seat. It may get it's signal from there.
just a thought
http://www.customdynamics.com/plasma_rod_led_lights.htm
#188
offthewall / 14FLHX Check out the below link. If you scroll down about half way and there is a video of a 2010 Roadglide that shows the turns as "off to bright". I realize this just a video so we don't know for sure if that's how it really is. I'm wondering if hooking up to the rear module at the fender tip makes a difference vs under the seat. It may get it's signal from there. just a thought http://www.customdynamics.com/plasma_rod_led_lights.htm
It's using the TFC3's to add RUN as well that gives the dim/bright turns. That i'm going to pass on and leave as is.
Sent from my iPhone using IB AutoGroup
