2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
‘14 Ultra Limited ACR Connectors
Old Today | 02:36 PM
GalvTexGuy's Avatar
GalvTexGuy
Default ‘14 Ultra Limited ACR Connectors
Does anyone know where they are located and what it takes to get to them so I can unplug them. The service manual says the ACRs need to be disabled in order to check compression, but it doesn’t say how. Thanks.
Old Today | 06:32 PM
14GuineaPig's Avatar
14GuineaPig
Unplug them. They are in the top of the heads. See page 7-45 of your service manual.
GalvTexGuy (Today)
Old Today | 06:42 PM
GalvTexGuy's Avatar
GalvTexGuy
I guess I need to remove the fuel tank to get to them or can I get to them behind the throttle body? Also, it looks like I can disable them if I pull the fuel pump fuse since that’s where they’re powered from according to @Vernal in this thread.
Old Today | 07:32 PM
Vernal's Avatar
Vernal
@GalvTexGuy Could you just put the bike in neutral and jump the starter to do your test? Ignition off...
The system fuse provides the power to the ACRs. Looks like ECM provides power to System Power that goes through the system fuse and powers the ACRs with the V/GN.
GalvTexGuy (Today)
Old Today | 08:02 PM
GalvTexGuy's Avatar
GalvTexGuy
I suppose that would be another option if I can’t find/get to the ACR connectors, since I now see there is no fuse for the fuel pump and, as it turns out, the ACRs don’t get power from the fuel pump after all. Thanks for the suggestion.
Vernal (Today)
Harleyonthebrain
08-17-2023 08:21 AM
Highwayman99
Electrical/Lighting/Alarm
03-25-2023 04:11 PM
Jshipley90
08-23-2015 08:20 PM
jpooch00
10-23-2009 08:31 AM
sinsee
04-23-2007 02:28 PM
Quick Reply: ‘14 Ultra Limited ACR Connectors
